I need to control the wake-up of my RAK19003 from standby mode.
I have a RAK4931, RAK12500 GNSS GPS and RAK1904 3-Axis connected to the board.
Is it possible to use the UART or I2C pin as a Wake Up user button?
Because somewhere they warned that using the UART or I2C pin is not recommended:
• Pressing the button on SDA/SCL will cause a “short to ground” on I2C, and if you connect something there later, it will look like a broken bus (stuck I2C).
• Also, don’t use BOOT or UART pins, because you can block boot/flash or serial communication.
