RAK19007+RAK3401+RAK13302 External 5V and USB C power simultaneously
Using the RAK 1W starter kit that contains RAK19007+RAK3401+RAK13302 with Meshcore.io stock repeater firmware. I am using external 5V 20W power, no solar and no battery hooked up as its an indoor install.
I would also like to simultaneously have the USB C connected to a Raspberry Pi to maintain firmware and capture mesh packet logging.
Since its receiving power from two independent sources (5V external power and USB C power from a Raspberry Pi) - Is this dual power configuration supported?
Thank you!
Yes, you can use the external 5V and USB together.
