I have an issue with my RAK2171, the device will connect with Bluetooth only the first time with the scanner.
But whenever I want to connect again to manage the device it will not connect.
So I have to delete the device and lose all the data and connect again with the scanner.
There is another issue, if the device is connected to Helium (not as client or host), then I will not be able to delete it because it is required to connect via Bluetooth first, so I can not connect or delete the device in this case.
any advise or solution?
Best Regards …
