mistral101
(Paul brouillette)
November 17, 2021, 10:18pm
1
Hi all,
Just new guy working with Rak2245. I’m working fine with gateway connected to TTI. I’m trying to transfer to Helium. I follow the instruction but I stop here .with that message:
pi@rak-gateway-2245:~ $ git clone GitHub - RAKWireless/RAK2245_for_helium: RAK2245 for helium ~/RAK2245_for_helium
Cloning into ‘/home/pi/RAK2245_for_helium’…
fatal: unable to access ‘GitHub - RAKWireless/RAK2245_for_helium: RAK2245 for helium ’: Failed to connect to 192.168.6.54 port 1080: No route to host
Need help
Paul
cstratton
(Chris)
November 18, 2021, 12:58am
2
Something odd is going on with that command or else your pi’s network connection, and 192.168.x.x is private non-routable address space.
If that’s the repo you want, try giving the actual git URL
git clone https://github.com/RAKWireless/RAK2245_for_helium.git
Also AFAIK while this can function as a gateway you won’t earn rewards without a purpose built box.
Hobo
(Vladislav Yordanov)
November 18, 2021, 7:49am
3
Hie @mistral101
No idea why your are using this repo, but the one below I have tested and it actually works. The tutorial is pretty straightforward:
Vladislav
mistral101
(Paul brouillette)
November 18, 2021, 2:58pm
4
Thanks Vladislav It’s looking better with that repo.
Waiting or data now
pi@rak-gateway-2245:~ $ sudo systemctl restart helium_gateway
pi@rak-gateway-2245:~ $ sudo tail -f /var/log/syslog | grep helium_gateway
Nov 18 09:40:13 rak-gateway-2245 helium_gateway[20704]: starting, oui: 9, uri: http://44.238.156.97:8080/ , pubkey: module: router
Nov 18 09:40:13 rak-gateway-2245 helium_gateway[20704]: starting, oui: 4, uri: http://54.193.165.228:8080/ , pubkey: Rxcsv, module: router
Nov 18 09:40:13 rak-gateway-2245 helium_gateway[20704]: starting, oui: 2, uri: http://54.176.88.149:8080/ , pubkey: , module: router
Nov 18 09:40:13 rak-gateway-2245 helium_gateway[20704]: updated routing to height 1102336, module: dispatcher
Nov 18 09:40:13 rak-gateway-2245 helium_gateway[20704]: starting, oui: 1, uri: http://52.8.80.146:8080/ , pubkey: , module: router
Nov 18 09:50:12 rak-gateway-2245 helium_gateway[20704]: no update found, module: updater
mistral101
(Paul brouillette)
November 19, 2021, 1:37pm
5
Data is there. Hard time with download command via Helium to Dragino LSN50
