I found on /var/log/syslog
Aug 5 16:46:23 rak-gateway ttn-gateway[1513]: JSON up: {“stat”:{“time”:“2019-08-05 14:45:53 GMT”,“lati”:49.86475,“long”:10.23891,“alti”:205,“rxnb”:1,“rxok”:1,“rxfw”:1,“ackr”:100.0,“dwnb”:1,“txnb”:0}}
Aug 5 16:46:23 rak-gateway ttn-gateway[1513]: INFO: [up] PUSH_ACK received in 35 ms
Aug 5 16:46:23 rak-gateway ttn-gateway[1513]: INFO: [down] PULL_ACK received in 33 ms
Aug 5 16:46:23 rak-gateway ttn-gateway[1513]: INFO: Received pkt from mote: 26011006 (fcnt=0)
Aug 5 16:46:23 rak-gateway ttn-gateway[1513]: JSON up: {“rxpk”:[{“tmst”:2979488828,“time”:“2019-08-05T14:45:59.136798Z”,“tmms”:1249051578136,“chan”:2,“rfch”:1,“freq”:868.500000,“stat”:1,“modu”:“LORA”,“datr”:“SF10BW125”,“codr”:“4/5”,“lsnr”:8.8,“rssi”:-64,“size”:22,“data”:“gAYQASaAAAAAdffg2sSzhQw4SrTsYA==”}]}
Aug 5 16:46:23 rak-gateway ttn-gateway[1513]: INFO: [down] PULL_RESP received - token[220:24]
Aug 5 16:46:23 rak-gateway ttn-gateway[1513]: JSON down: {“txpk”:{“imme”:false,“tmst”:2981488828,“freq”:923.3,“rfch”:0,“powe”:20,“modu”:“LORA”,“datr”:“SF12BW500”,“codr”:“4/5”,“ipol”:true,“size”:19,“ncrc”:true,“data”:“YAYQASaloUsDVf8AAQFeJaHuVQ==”}}
Aug 5 16:46:23 rak-gateway ttn-gateway[1513]: ERROR: Packet REJECTED, unsupported frequency - 923300000 (min:863000000,max:870000000)
I see the concentrator software uses wrong frequencies for transmitting data packets.
The concentrator is the EU Version and so configured. But I see for incomming packets allways an answer with the wrong frequency of 923.3 MHz, Asia base frequency perhaps.
What went wrong? Software is 2.9R and 2.9.1
The error in update_gwid.sh is still existent. The script references only eth0 to calculate the gateway ID. This will go wrong with Pi 3 A+ or Pi Zero W without ethernet/lan!
This could also be a result of no eth0! The gateway was never seen at TTN.
With a Pi 3 B via eth0 i got a connection to the TTN server with RAK2245.
And no, I dislike the idea to plug a Pi plus RAK2245 with roof antenna in my home network.
