I flashed RAK2245 image file in LPWAN Gateway, and configure it, it started connected to WiFi and started receiving lora packets from end node and sent/receive from TTN server as well. After some period it stops connecting same WiFi. So I formatted the SD card and tried to put back new gateway firmware image file in SD card. But I’m not able to flash it saying error–>Something went wrong. If it is a compressed image, please check that the archive is not corrupted.
User did not grant permission.
Any solution for this. I tried to run application as administrator as well but showing same error.
@Hobo reflashed firmware in RAK2245. After powered up gateway, after 3 to 5 minutes access point Rakwireless_XXXX shows. I’m able to connect to to gateway using ssh but connection went inactive after some time before I can connect gateway to wifi.
Solved. it was permission issue, due current antivirus in PC user was not getting permission. Running the Balena tools as an administrator seems to solve.
I’d sooooo definitely do it the other way round - telling it to be a client without giving it client details may have issues, particularly as it won’t know what region to use.
If you put an empty file in the boot volume called rak_ap it will let you back in again if you’ve ended up rebooting, see:
Created rak_ap file successfully in boot folder. Inserted sd card in RAK2245 gateway and powered the gateway. But now it not showing as wireless access point.
I’m not sure what the effects on editing the files manually would be on the restore to AP mode.
Can you put a monitor & keyboard on to the Pi and just install at the command line directly - it may be requiring an apt update. Or there may be something going on with the wifi stack …
@nmcc@Hobo just removed SD card, formatted it and flashed new gateway firmware in it. Created new rak_ap file as well.(not editing files manually) When try to connect with with wifi it showing same error “could not communicate with wpa_supplicant”.
