Hello, i’m trying to make a successful join. The node sends the join, arrives to the log arrives and it’s written and the attempt appears at the ttn. 4 seconds later it returns the response of the join accept but in the node it’s denied.
gateway log:
– Logs begin at Thu 2016-11-03 17:16:43 GMT, end at Tue 2020-02-18 22:37:34 GMT. –
Feb 18 22:37:10 rak-gateway ttn-gateway[956]: # CRC_OK: 0.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
Feb 18 22:37:10 rak-gateway ttn-gateway[956]: # RF packets forwarded: 0 (0 bytes)
Feb 18 22:37:10 rak-gateway ttn-gateway[956]: # PUSH_DATA datagrams sent: 1 (155 bytes)
Feb 18 22:37:10 rak-gateway ttn-gateway[956]: # PUSH_DATA acknowledged: 0.00%
Feb 18 22:37:10 rak-gateway ttn-gateway[956]: ### [DOWNSTREAM] ###
Feb 18 22:37:10 rak-gateway ttn-gateway[956]: # PULL_DATA sent: 3 (100.00% acknowledged)
Feb 18 22:37:10 rak-gateway ttn-gateway[956]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Feb 18 22:37:10 rak-gateway ttn-gateway[956]: # RF packets sent to concentrator: 0 (0 bytes)
Feb 18 22:37:10 rak-gateway ttn-gateway[956]: # TX errors: 0
Feb 18 22:37:10 rak-gateway ttn-gateway[956]: # BEACON queued: 0
Feb 18 22:37:10 rak-gateway ttn-gateway[956]: # BEACON sent so far: 0
Feb 18 22:37:10 rak-gateway ttn-gateway[956]: # BEACON rejected: 0
Feb 18 22:37:10 rak-gateway ttn-gateway[956]: ### [JIT] ###
Feb 18 22:37:10 rak-gateway ttn-gateway[956]: # SX1301 time (PPS): 2732201036
Feb 18 22:37:10 rak-gateway ttn-gateway[956]: src/jitqueue.c:448:jit_print_queue(): INFO: [jit] queue is empty
Feb 18 22:37:10 rak-gateway ttn-gateway[956]: ### [GPS] ###
Feb 18 22:37:10 rak-gateway ttn-gateway[956]: # Valid time reference (age: 0 sec)
Feb 18 22:37:10 rak-gateway ttn-gateway[956]: # GPS coordinates: latitude -34.89400, longitude -54.96862, altitude 15 m
Feb 18 22:37:10 rak-gateway ttn-gateway[956]: ##### END #####
Feb 18 22:37:10 rak-gateway ttn-gateway[956]: JSON up: {“stat”:{“time”:“2020-02-18 22:35:40 GMT”,“lati”:-34.89400,“long”:-54.96862,“alti”:15,“rxnb”:0,“rxok”:0,“rxfw”:0,
Feb 18 22:37:10 rak-gateway ttn-gateway[956]: INFO: [down] PULL_ACK received in 199 ms
Feb 18 22:37:10 rak-gateway ttn-gateway[956]: INFO: [down] PULL_ACK received in 200 ms
Feb 18 22:37:10 rak-gateway ttn-gateway[956]: INFO: Disabling GPS mode for concentrator’s counter…
Feb 18 22:37:10 rak-gateway ttn-gateway[956]: INFO: host/sx1301 time offset=(1582062607s:800269µs) - drift=-55µs
Feb 18 22:37:10 rak-gateway ttn-gateway[956]: INFO: Enabling GPS mode for concentrator’s counter.
Feb 18 22:37:10 rak-gateway ttn-gateway[956]: ##### 2020-02-18 22:36:10 GMT #####
Feb 18 22:37:10 rak-gateway ttn-gateway[956]: ### [UPSTREAM] ###
Feb 18 22:37:10 rak-gateway ttn-gateway[956]: # RF packets received by concentrator: 0
Feb 18 22:37:10 rak-gateway ttn-gateway[956]: # SX1301 time (PPS): 2762688183
Feb 18 22:37:10 rak-gateway ttn-gateway[956]: # GPS coordinates: latitude -34.89403, longitude -54.96871, altitude 20 m
Feb 18 22:37:10 rak-gateway ttn-gateway[956]: JSON up: {“stat”:{“time”:“2020-02-18 22:36:10 GMT”,“lati”:-34.89403,“long”:-54.96871,“alti”:20,“rxnb”:0,“rxok”:0,“rxfw”:0,
Feb 18 22:37:10 rak-gateway ttn-gateway[956]: ##### 2020-02-18 22:36:40 GMT #####
Feb 18 22:37:10 rak-gateway ttn-gateway[956]: # SX1301 time (PPS): 2792201044
Feb 18 22:37:10 rak-gateway ttn-gateway[956]: # GPS coordinates: latitude -34.89403, longitude -54.96878, altitude 22 m
Feb 18 22:37:10 rak-gateway ttn-gateway[956]: JSON up: {“stat”:{“time”:“2020-02-18 22:36:40 GMT”,“lati”:-34.89403,“long”:-54.96878,“alti”:22,“rxnb”:0,“rxok”:0,“rxfw”:0,
Feb 18 22:37:10 rak-gateway ttn-gateway[956]: INFO: host/sx1301 time offset=(1582062607s:800216µs) - drift=-53µs
Feb 18 22:37:10 rak-gateway ttn-gateway[956]: ##### 2020-02-18 22:37:10 GMT #####
Feb 18 22:37:10 rak-gateway ttn-gateway[956]: # SX1301 time (PPS): 2822688553
Feb 18 22:37:10 rak-gateway ttn-gateway[956]: # GPS coordinates: latitude -34.89402, longitude -54.96873, altitude 23 m
Feb 18 22:37:34 rak-gateway sudo[24388]: pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/bin/journalctl --since 2020-02-18 22:36:00
Feb 18 22:37:34 rak-gateway sudo[24388]: pam_unix(sudo:session): session opened for user root by pi(uid=0)
