Issue: RAK 2245 is not seen in ChirpStack Application Server despite following all steps outlined in the RAK 2245 Quick Start Guide. I’m currently attempting to use the built-in ChirpStack, but am receiving “Last Seen at: Never”
I am fairly new to RAK/LoRa/ChirpStack, so I am not sure what to do in the way of troubleshooting. I can successfully ping google.com, so I don’t believe my internet connection is the issue.
Setup: RAK2245
Server: RaspBerry Pi 3B+ w/ latest RAK2245 firmware installed
Output from sudo gateway-version sans EUI
Raspberry Pi 3 Model B Rev 1.2, OS “10 (buster)”, 4.19.97-v7+.
RAKWireless gateway RAK7243 no LTE version 4.2.5R install from firmware.
Because I am a new user I cannot embed more than one media post, but I can post my log outputs for the ChirpStack Application Server, Network Server, and Gateway Bridge in the replies (nothing appears abnormal to me)
I can provide additional information if needed/desired, any help would be greatly appreciated!
Might sounds stupid, but I want to make sure that the gateway is pointed to the build-in ChirpStack.
Can you check that in the sudo gateway-config command (Setup RAK Gateway Channel Plan). Server is ChirpStack must be selected:
Just to add some more possibly helpful information, after performing “sudo gateway-config” I went into Option 4, “Edit packet-forwarder config”. This took me to lora_pkt_fwd/global_conf.json and I noticed that under gateway_conf, gateway_ID was set to all 0’s and not my Gateway EUI (local_conf.json also exists but only contains the Gateway EUI, no other information). I changed that value to my Gateway EUI, restarted the packet forwarder, performed a reboot, but still did not see any change in the “Last seen at” status. I took a look in daemon.log and noticed the following:
Setting the EUI in the global_conf file is not mandatory, as the local_conf file overwrites the parameters in the global_conf one. But it is not a problem nor it will affect gateway in any way.
It seems that the problem is caused by the concentrator that is not starting:
