hi Velev,
Thanks for the reply correct the problem looks coming from the mac but set_eui.sh is already done to change to wlan, I have change it bu the same problem, when I look to "sudo gateway-config” the EUI looks the one of the wifi, so it looks coming from MAC yes but I need to to do the change in another place ?
#! /bin/bash
GATEWAY_EUI=""
if [ ! -e “/opt/ttn-gateway/packet_forwarder/lora_pkt_fwd/local_conf.json” ]; then
GATEWAY_EUI_NIC=“eth0”
if [[ grep "$GATEWAY_EUI_NIC" /proc/net/dev == “” ]]; then
GATEWAY_EUI_NIC=“wlan0”
fi
if [[ `grep "$GATEWAY_EUI_NIC" /proc/net/dev` == "" ]]; then
echo "ERROR: No network interface found. Cannot set gateway ID."
exit 1
fi
GATEWAY_EUI=$(ip link show $GATEWAY_EUI_NIC | awk '/ether/ {print $2}' | awk -F\: '{print $1$2$3"FFFE"$4$5$6}')
GATEWAY_EUI=${GATEWAY_EUI^^}
LOCAL_CONFIG_FILE=/opt/ttn-gateway/packet_forwarder/lora_pkt_fwd/local_conf.json
echo -e "{\n\t\"gateway_conf\": {\n\t\t\"gateway_ID\": \"$GATEWAY_EUI\" \n\t}\n}" >$LOCAL_CONFIG_FILE
echo "$GATEWAY_EUI"
fi
llogin as: pi
[email protected]’s password:
Linux rak-gateway 4.19.42+ #1219 Tue May 14 21:16:38 BST 2019 armv6l
… a new password.
pi@rak-gateway:~ $ sudo tail -f /var/log/syslog
Jun 23 10:32:35 rak-gateway systemd[655]: Listening on GnuPG cryptographic agent (access for web browsers).
Jun 23 10:32:35 rak-gateway systemd[655]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
Jun 23 10:32:35 rak-gateway systemd[655]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
Jun 23 10:32:35 rak-gateway systemd[655]: Reached target Paths.
Jun 23 10:32:35 rak-gateway systemd[655]: Reached target Sockets.
Jun 23 10:32:35 rak-gateway systemd[655]: Reached target Timers.
Jun 23 10:32:35 rak-gateway systemd[655]: Reached target Basic System.
Jun 23 10:32:35 rak-gateway systemd[655]: Reached target Default.
Jun 23 10:32:35 rak-gateway systemd[655]: Startup finished in 154ms.
Jun 23 10:32:35 rak-gateway systemd[1]: Started User Manager for UID 1000.
Jun 23 10:34:13 rak-gateway ttn-gateway[528]: src/jitqueue.c:448:jit_print_queue(): INFO: [jit] queue is empty
Jun 23 10:34:13 rak-gateway ttn-gateway[528]: ### [GPS] ###
Jun 23 10:34:13 rak-gateway ttn-gateway[528]: # Valid time reference (age: 0 sec)
Jun 23 10:34:13 rak-gateway ttn-gateway[528]: # GPS coordinates: latitude 4.43009, longitude 5.06528, altitude 199 m
Jun 23 10:34:13 rak-gateway ttn-gateway[528]: ##### END #####
Jun 23 10:34:13 rak-gateway ttn-gateway[528]: JSON up: {“stat”:{“time”:“2019-06-23 09:32:13 GMT”,“lati”:4.43009,“long”:5.06528,“alti”:199,“rxnb”:0,“rxok”:0,“rxfw”:0,“ackr”:0.0,“dwnb”:0,“txnb”:0}}
Jun 23 10:34:13 rak-gateway ttn-gateway[528]: INFO: [up] PUSH_ACK received in 108 ms
Jun 23 10:34:13 rak-gateway ttn-gateway[528]: INFO: [down] PULL_ACK received in 109 ms
Jun 23 10:34:13 rak-gateway ttn-gateway[528]: INFO: [down] PULL_ACK received in 113 ms
Jun 23 10:34:13 rak-gateway ttn-gateway[528]: INFO: Disabling GPS mode for concentrator’s counter…
Jun 23 10:34:13 rak-gateway ttn-gateway[528]: INFO: host/sx1301 time offset=(1561282300s:600643µs) - drift=9718279µs
Jun 23 10:34:13 rak-gateway ttn-gateway[528]: INFO: Enabling GPS mode for concentrator’s counter.
Jun 23 10:34:13 rak-gateway ttn-gateway[528]: ##### 2019-06-23 09:32:43 GMT #####
Jun 23 10:34:13 rak-gateway ttn-gateway[528]: ### [UPSTREAM] ###
Jun 23 10:34:13 rak-gateway ttn-gateway[528]: # RF packets received by concentrator: 0
Jun 23 10:34:13 rak-gateway ttn-gateway[528]: # CRC_OK: 0.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
Jun 23 10:34:13 rak-gateway ttn-gateway[528]: # RF packets forwarded: 0 (0 bytes)
Jun 23 10:34:13 rak-gateway ttn-gateway[528]: # PUSH_DATA datagrams sent: 1 (153 bytes)
Jun 23 10:34:13 rak-gateway ttn-gateway[528]: # PUSH_DATA acknowledged: 100.00%
Jun 23 10:34:13 rak-gateway ttn-gateway[528]: ### [DOWNSTREAM] ###
Jun 23 10:34:13 rak-gateway ttn-gateway[528]: # PULL_DATA sent: 3 (100.00% acknowledged)
Jun 23 10:34:13 rak-gateway ttn-gateway[528]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Jun 23 10:34:13 rak-gateway ttn-gateway[528]: # RF packets sent to concentrator: 0 (0 bytes)
Jun 23 10:34:13 rak-gateway ttn-gateway[528]: # TX errors: 0
Jun 23 10:34:13 rak-gateway ttn-gateway[528]: # BEACON queued: 0
Jun 23 10:34:13 rak-gateway ttn-gateway[528]: # BEACON sent so far: 0
Jun 23 10:34:13 rak-gateway ttn-gateway[528]: # BEACON rejected: 0
Jun 23 10:34:13 rak-gateway ttn-gateway[528]: ### [JIT] ###
Jun 23 10:34:13 rak-gateway ttn-gateway[528]: # SX1301 time (PPS): 62553348
Jun 23 10:34:13 rak-gateway ttn-gateway[528]: # GPS coordinates: latitude 4.43004, longitude 5.06526, altitude 200 m
Jun 23 10:34:13 rak-gateway ttn-gateway[528]: JSON up: {“stat”:{“time”:“2019-06-23 09:32:43 GMT”,“lati”:4.43004,“long”:5.06526,“alti”:200,“rxnb”:0,“rxok”:0,“rxfw”:0,“ackr”:100.0,“dwnb”:0,“txnb”:0}}
Jun 23 10:34:13 rak-gateway ttn-gateway[528]: INFO: [down] PULL_ACK received in 111 ms
Jun 23 10:34:13 rak-gateway ttn-gateway[528]: INFO: [down] PULL_ACK received in 128 ms
Jun 23 10:34:13 rak-gateway ttn-gateway[528]: ##### 2019-06-23 09:33:13 GMT #####
Jun 23 10:35:43 rak-gateway ttn-gateway[528]: ### [UPSTREAM] ###
Jun 23 10:35:43 rak-gateway ttn-gateway[528]: # RF packets received by concentrator: 1
Jun 23 10:35:43 rak-gateway ttn-gateway[528]: # CRC_OK: 0.00%, CRC_FAIL: 100.00%, NO_CRC: 0.00%
Jun 23 10:35:43 rak-gateway ttn-gateway[528]: # RF packets forwarded: 0 (0 bytes)
Jun 23 10:35:43 rak-gateway ttn-gateway[528]: # PUSH_DATA datagrams sent: 1 (155 bytes)
Jun 23 10:35:43 rak-gateway ttn-gateway[528]: # PUSH_DATA acknowledged: 100.00%
Jun 23 10:35:43 rak-gateway ttn-gateway[528]: ### [DOWNSTREAM] ###
Jun 23 10:35:43 rak-gateway ttn-gateway[528]: # PULL_DATA sent: 3 (100.00% acknowledged)
Jun 23 10:35:43 rak-gateway ttn-gateway[528]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Jun 23 10:35:43 rak-gateway ttn-gateway[528]: # RF packets sent to concentrator: 0 (0 bytes)
Jun 23 10:35:43 rak-gateway ttn-gateway[528]: # TX errors: 0
Jun 23 10:35:43 rak-gateway ttn-gateway[528]: # BEACON queued: 0
Jun 23 10:35:43 rak-gateway ttn-gateway[528]: # BEACON sent so far: 0
Jun 23 10:35:43 rak-gateway ttn-gateway[528]: # BEACON rejected: 0
Jun 23 10:35:43 rak-gateway ttn-gateway[528]: ### [JIT] ###
Jun 23 10:35:43 rak-gateway ttn-gateway[528]: # SX1301 time (PPS): 182582548
Jun 23 10:35:43 rak-gateway ttn-gateway[528]: src/jitqueue.c:448:jit_print_queue(): INFO: [jit] queue is empty
Jun 23 10:35:43 rak-gateway ttn-gateway[528]: ### [GPS] ###
Jun 23 10:35:43 rak-gateway ttn-gateway[528]: # Valid time reference (age: 0 sec)
Jun 23 10:35:43 rak-gateway ttn-gateway[528]: # GPS coordinates: latitude 4.43007, longitude 5.06530, altitude 207 m
Jun 23 10:35:43 rak-gateway ttn-gateway[528]: ##### END #####
Jun 23 10:35:43 rak-gateway ttn-gateway[528]: JSON up: {“stat”:{“time”:“2019-06-23 09:34:43 GMT”,“lati”:4.43007,“long”:5.06530,“alti”:207,“rxnb”:1,“rxok”:0,“rxfw”:0,“ackr”:100.0,“dwnb”:0,“txnb”:0}}
Jun 23 10:35:43 rak-gateway ttn-gateway[528]: INFO: [up] PUSH_ACK received in 110 ms
Jun 23 10:35:43 rak-gateway ttn-gateway[528]: INFO: [down] PULL_ACK received in 111 ms
Jun 23 10:35:43 rak-gateway ttn-gateway[528]: INFO: [down] PULL_ACK received in 115 ms
Jun 23 10:35:43 rak-gateway ttn-gateway[528]: INFO: [down] PULL_ACK received in 125 ms
Jun 23 10:35:43 rak-gateway ttn-gateway[528]: ##### 2019-06-23 09:35:13 GMT #####
Jun 23 10:35:43 rak-gateway ttn-gateway[528]: # RF packets received by concentrator: 0
Jun 23 10:35:43 rak-gateway ttn-gateway[528]: # CRC_OK: 0.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
Jun 23 10:35:43 rak-gateway ttn-gateway[528]: # SX1301 time (PPS): 212400919
Jun 23 10:35:43 rak-gateway ttn-gateway[528]: # GPS coordinates: latitude 4.43007, longitude 5.06530, altitude 210 m
Jun 23 10:35:43 rak-gateway ttn-gateway[528]: JSON up: {“stat”:{“time”:“2019-06-23 09:35:13 GMT”,“lati”:4.43007,“long”:5.06530,“alti”:210,“rxnb”:0,“rxok”:0,“rxfw”:0,“ackr”:100.0,“dwnb”:0,“txnb”:0}}
Jun 23 10:35:43 rak-gateway ttn-gateway[528]: INFO: [up] PUSH_ACK received in 118 ms
Jun 23 10:35:43 rak-gateway ttn-gateway[528]: INFO: [down] PULL_ACK received in 114 ms
Jun 23 10:35:43 rak-gateway ttn-gateway[528]: INFO: [down] PULL_ACK received in 112 ms
Jun 23 10:35:43 rak-gateway ttn-gateway[528]: INFO: [down] PULL_ACK received in 109 ms
Jun 23 10:35:43 rak-gateway ttn-gateway[528]: INFO: Disabling GPS mode for concentrator’s counter…
Jun 23 10:35:43 rak-gateway ttn-gateway[528]: INFO: host/sx1301 time offset=(1561282300s:566372µs) - drift=-6350µs
Jun 23 10:35:43 rak-gateway ttn-gateway[528]: INFO: Enabling GPS mode for concentrator’s counter.
Jun 23 10:35:43 rak-gateway ttn-gateway[528]: ##### 2019-06-23 09:35:43 GMT #####
Jun 23 10:35:43 rak-gateway ttn-gateway[528]: # SX1301 time (PPS): 242589546
Jun 23 10:36:59 rak-gateway systemd[1]: Stopping The Things Network Gateway…
Jun 23 10:36:59 rak-gateway ttn-gateway[528]: ### [GPS] ###
Jun 23 10:36:59 rak-gateway ttn-gateway[528]: # Valid time reference (age: 0 sec)
Jun 23 10:36:59 rak-gateway ttn-gateway[528]: # GPS coordinates: latitude 4.43008, longitude 5.06529, altitude 214 m
Jun 23 10:36:59 rak-gateway ttn-gateway[528]: ##### END #####
Jun 23 10:36:59 rak-gateway ttn-gateway[528]: JSON up: {“stat”:{“time”:“2019-06-23 09:35:43 GMT”,“lati”:4.43008,“long”:5.06529,“alti”:214,“rxnb”:0,“rxok”:0,“rxfw”:0,“ackr”:100.0,“dwnb”:0,“txnb”:0}}
Jun 23 10:36:59 rak-gateway ttn-gateway[528]: INFO: [up] PUSH_ACK received in 107 ms
Jun 23 10:36:59 rak-gateway ttn-gateway[528]: INFO: [down] PULL_ACK received in 114 ms
Jun 23 10:36:59 rak-gateway ttn-gateway[528]: INFO: [down] PULL_ACK received in 103 ms
Jun 23 10:36:59 rak-gateway ttn-gateway[528]: INFO: [down] PULL_ACK received in 107 ms
Jun 23 10:36:59 rak-gateway ttn-gateway[528]: ##### 2019-06-23 09:36:13 GMT #####
Jun 23 10:36:59 rak-gateway ttn-gateway[528]: ### [UPSTREAM] ###
Jun 23 10:36:59 rak-gateway ttn-gateway[528]: # RF packets received by concentrator: 0
Jun 23 10:36:59 rak-gateway ttn-gateway[528]: # CRC_OK: 0.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
Jun 23 10:36:59 rak-gateway ttn-gateway[528]: # RF packets forwarded: 0 (0 bytes)
Jun 23 10:36:59 rak-gateway ttn-gateway[528]: # PUSH_DATA datagrams sent: 1 (155 bytes)
Jun 23 10:36:59 rak-gateway ttn-gateway[528]: # PUSH_DATA acknowledged: 100.00%
Jun 23 10:36:59 rak-gateway ttn-gateway[528]: ### [DOWNSTREAM] ###
Jun 23 10:36:59 rak-gateway ttn-gateway[528]: # PULL_DATA sent: 3 (100.00% acknowledged)
Jun 23 10:36:59 rak-gateway ttn-gateway[528]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Jun 23 10:36:59 rak-gateway ttn-gateway[528]: # RF packets sent to concentrator: 0 (0 bytes)
Jun 23 10:36:59 rak-gateway ttn-gateway[528]: # TX errors: 0
Jun 23 10:36:59 rak-gateway ttn-gateway[528]: # BEACON queued: 0
Jun 23 10:36:59 rak-gateway ttn-gateway[528]: # BEACON sent so far: 0
Jun 23 10:36:59 rak-gateway ttn-gateway[528]: # BEACON rejected: 0
Jun 23 10:36:59 rak-gateway ttn-gateway[528]: ### [JIT] ###
Jun 23 10:36:59 rak-gateway ttn-gateway[528]: # SX1301 time (PPS): 272400929
Jun 23 10:36:59 rak-gateway ttn-gateway[528]: src/jitqueue.c:448:jit_print_queue(): INFO: [jit] queue is empty
Jun 23 10:36:59 rak-gateway ttn-gateway[528]: # GPS coordinates: latitude 4.43011, longitude 5.06530, altitude 217 m
Jun 23 10:36:59 rak-gateway ttn-gateway[528]: JSON up: {“stat”:{“time”:“2019-06-23 09:36:13 GMT”,“lati”:4.43011,“long”:5.06530,“alti”:217,“rxnb”:0,“rxok”:0,“rxfw”:0,“ackr”:100.0,“dwnb”:0,“txnb”:0}}
Jun 23 10:36:59 rak-gateway ttn-gateway[528]: INFO: [up] PUSH_ACK received in 103 ms
Jun 23 10:36:59 rak-gateway ttn-gateway[528]: INFO: [down] PULL_ACK received in 108 ms
Jun 23 10:36:59 rak-gateway ttn-gateway[528]: INFO: [down] PULL_ACK received in 104 ms
Jun 23 10:36:59 rak-gateway ttn-gateway[528]: INFO: Disabling GPS mode for concentrator’s counter…
Jun 23 10:36:59 rak-gateway ttn-gateway[528]: INFO: host/sx1301 time offset=(1561282300s:575447µs) - drift=9075µs
Jun 23 10:36:59 rak-gateway ttn-gateway[528]: INFO: Enabling GPS mode for concentrator’s counter.
Jun 23 10:36:59 rak-gateway ttn-gateway[528]: ##### 2019-06-23 09:36:43 GMT #####
Jun 23 10:36:59 rak-gateway systemd[1]: Stopped The Things Network Gateway.
Jun 23 10:36:59 rak-gateway ttn-gateway[528]: # SX1301 time (PPS): 302580949
Jun 23 10:36:59 rak-gateway ttn-gateway[528]: # GPS coordinates: latitude 4.43011, longitude 5.06531, altitude 218 m
Jun 23 10:36:59 rak-gateway ttn-gateway[528]: JSON up: {“stat”:{“time”:“2019-06-23 09:36:43 GMT”,“lati”:4.43011,“long”:5.06531,“alti”:218,“rxnb”:0,“rxok”:0,“rxfw”:0,“ackr”:100.0,“dwnb”:0,“txnb”:0}}
Jun 23 10:36:59 rak-gateway ttn-gateway[528]: INFO: [up] PUSH_ACK received in 112 ms
Jun 23 10:36:59 rak-gateway ttn-gateway[528]: INFO: [down] PULL_ACK received in 111 ms
Jun 23 10:36:59 rak-gateway ttn-gateway[528]: ##### 2019-06-23 09:36:59 GMT #####
Jun 23 10:36:59 rak-gateway ttn-gateway[528]: # PULL_DATA sent: 2 (100.00% acknowledged)
Jun 23 10:36:59 rak-gateway ttn-gateway[528]: # SX1301 time (PPS): 318400936
Jun 23 10:36:59 rak-gateway ttn-gateway[528]: # GPS coordinates: latitude 4.43011, longitude 5.06529, altitude 215 m
Jun 23 10:36:59 rak-gateway ttn-gateway[528]: INFO: End of GPS thread
Jun 23 10:36:59 rak-gateway ttn-gateway[528]: INFO: End of upstream thread
Jun 23 10:36:59 rak-gateway ttn-gateway[528]: WARNING: failed to close GPS successfully
Jun 23 10:36:59 rak-gateway ttn-gateway[528]: INFO: concentrator stopped successfully
Jun 23 10:36:59 rak-gateway ttn-gateway[528]: INFO: Exiting packet forwarder program
Jun 23 10:36:59 rak-gateway systemd[1]: Started The Things Network Gateway.
Jun 23 10:37:00 rak-gateway ttn-gateway[773]: Device “eth0” does not exist.
Jun 23 10:37:00 rak-gateway ttn-gateway[773]: Gateway_ID set to fffe in file ./local_conf.json
Jun 23 10:37:01 rak-gateway kernel: [ 354.438121] sysrq: SysRq : HELP : loglevel(0-9) reboot(b) crash© terminate-all-tasks(e) memory-full-oom-kill(f) kill-all-tasks(i) thaw-filesystems(j) sak(k) show-memory-usage(m) nice-all-RT-tasks(n) poweroff(o) show-registers§ show-all-timers(q) unraw® sync(s) show-task-states(t) unmount(u) show-blocked-tasks(w) dump-ftrace-buffer(z)
Jun 23 10:37:04 rak-gateway ttn-gateway[773]: *** Beacon Packet Forwarder for Lora Gateway ***
Jun 23 10:37:04 rak-gateway ttn-gateway[773]: Version: 4.0.1
Jun 23 10:37:04 rak-gateway ttn-gateway[773]: *** Lora concentrator HAL library version info ***
Jun 23 10:37:04 rak-gateway ttn-gateway[773]: Version: 5.0.1;
Jun 23 10:37:04 rak-gateway ttn-gateway[773]: INFO: Little endian host
Jun 23 10:37:04 rak-gateway ttn-gateway[773]: INFO: found global configuration file global_conf.json, parsing it
Jun 23 10:37:04 rak-gateway ttn-gateway[773]: INFO: global_conf.json does contain a JSON object named SX1301_conf, parsing SX1301 parameters
Jun 23 10:37:04 rak-gateway ttn-gateway[773]: INFO: lorawan_public 1, clksrc 1
Jun 23 10:37:04 rak-gateway ttn-gateway[773]: INFO: no configuration for LBT
Jun 23 10:37:04 rak-gateway ttn-gateway[773]: INFO: antenna_gain 0 dBi
Jun 23 10:37:04 rak-gateway ttn-gateway[773]: INFO: Configuring TX LUT with 16 indexes
Jun 23 10:37:04 rak-gateway ttn-gateway[773]: INFO: radio 0 enabled (type SX1257), center frequency 867500000, RSSI offset -166.000000, tx enabled 1, tx_notch_freq 0
Jun 23 10:37:04 rak-gateway ttn-gateway[773]: INFO: radio 1 enabled (type SX1257), center frequency 868500000, RSSI offset -166.000000, tx enabled 0, tx_notch_freq 0
Jun 23 10:37:04 rak-gateway ttn-gateway[773]: INFO: Lora multi-SF channel 0> radio 1, IF -400000 Hz, 125 kHz bw, SF 7 to 12
Jun 23 10:37:04 rak-gateway ttn-gateway[773]: INFO: Lora multi-SF channel 1> radio 1, IF -200000 Hz, 125 kHz bw, SF 7 to 12
Jun 23 10:37:04 rak-gateway ttn-gateway[773]: INFO: Lora multi-SF channel 2> radio 1, IF 0 Hz, 125 kHz bw, SF 7 to 12
Jun 23 10:37:04 rak-gateway ttn-gateway[773]: INFO: Lora multi-SF channel 3> radio 0, IF -400000 Hz, 125 kHz bw, SF 7 to 12
Jun 23 10:37:04 rak-gateway ttn-gateway[773]: INFO: Lora multi-SF channel 4> radio 0, IF -200000 Hz, 125 kHz bw, SF 7 to 12
Jun 23 10:37:04 rak-gateway ttn-gateway[773]: INFO: Lora multi-SF channel 5> radio 0, IF 0 Hz, 125 kHz bw, SF 7 to 12
Jun 23 10:37:04 rak-gateway ttn-gateway[773]: INFO: Lora multi-SF channel 6> radio 0, IF 200000 Hz, 125 kHz bw, SF 7 to 12
Jun 23 10:37:04 rak-gateway ttn-gateway[773]: INFO: Lora multi-SF channel 7> radio 0, IF 400000 Hz, 125 kHz bw, SF 7 to 12
Jun 23 10:37:04 rak-gateway ttn-gateway[773]: INFO: Lora std channel> radio 1, IF -200000 Hz, 250000 Hz bw, SF 7
Jun 23 10:37:04 rak-gateway ttn-gateway[773]: INFO: FSK channel> radio 1, IF 300000 Hz, 125000 Hz bw, 50000 bps datarate
Jun 23 10:37:04 rak-gateway ttn-gateway[773]: INFO: global_conf.json does contain a JSON object named gateway_conf, parsing gateway parameters
Jun 23 10:37:04 rak-gateway ttn-gateway[773]: INFO: gateway MAC address is configured to 0000000000000000
Jun 23 10:37:04 rak-gateway ttn-gateway[773]: INFO: server hostname or IP address is configured to “router.eu.thethings.network”
Jun 23 10:37:04 rak-gateway ttn-gateway[773]: INFO: upstream port is configured to “1700”
Jun 23 10:37:04 rak-gateway ttn-gateway[773]: INFO: downstream port is configured to “1700”
Jun 23 10:37:04 rak-gateway ttn-gateway[773]: INFO: downstream keep-alive interval is configured to 10 seconds
Jun 23 10:37:04 rak-gateway ttn-gateway[773]: INFO: statistics display interval is configured to 30 seconds
Jun 23 10:37:04 rak-gateway ttn-gateway[773]: INFO: upstream PUSH_DATA time-out is configured to 100 ms
Jun 23 10:37:04 rak-gateway ttn-gateway[773]: INFO: packets received with a valid CRC will be forwarded
Jun 23 10:37:04 rak-gateway ttn-gateway[773]: INFO: packets received with a CRC error will NOT be forwarded
Jun 23 10:37:04 rak-gateway ttn-gateway[773]: INFO: packets received with no CRC will NOT be forwarded
Jun 23 10:37:04 rak-gateway ttn-gateway[773]: INFO: GPS serial port path is configured to “/dev/ttyAMA0”
Jun 23 10:37:04 rak-gateway ttn-gateway[773]: INFO: Reference latitude is configured to 10.000000 deg
Jun 23 10:37:04 rak-gateway ttn-gateway[773]: INFO: Reference longitude is configured to 20.000000 deg
Jun 23 10:37:04 rak-gateway ttn-gateway[773]: INFO: Reference altitude is configured to -1 meters
Jun 23 10:37:04 rak-gateway ttn-gateway[773]: INFO: fake GPS is disabled
Jun 23 10:37:04 rak-gateway ttn-gateway[773]: INFO: Auto-quit after 6 non-acknowledged PULL_DATA
Jun 23 10:37:04 rak-gateway ttn-gateway[773]: INFO: found local configuration file local_conf.json, parsing it
Jun 23 10:37:04 rak-gateway ttn-gateway[773]: INFO: redefined parameters will overwrite global parameters
Jun 23 10:37:04 rak-gateway ttn-gateway[773]: INFO: local_conf.json does not contain a JSON object named SX1301_conf
Jun 23 10:37:04 rak-gateway ttn-gateway[773]: INFO: local_conf.json does contain a JSON object named gateway_conf, parsing gateway parameters
Jun 23 10:37:04 rak-gateway ttn-gateway[773]: INFO: gateway MAC address is configured to 000000000000FFFE
Jun 23 10:37:04 rak-gateway ttn-gateway[773]: INFO: [main] TTY port /dev/ttyAMA0 open for GPS synchronization
Jun 23 10:37:04 rak-gateway ttn-gateway[773]: INFO: [main] concentrator started, packet can now be received
Jun 23 10:37:04 rak-gateway ttn-gateway[773]: INFO: Disabling GPS mode for concentrator’s counter…
Jun 23 10:37:04 rak-gateway ttn-gateway[773]: WARNING: [gps] could not get a valid message from GPS (no time)
Jun 23 10:37:04 rak-gateway ttn-gateway[773]: INFO: host/sx1301 time offset=(1561282621s:880714µs) - drift=1880242570µs
Jun 23 10:37:04 rak-gateway ttn-gateway[773]: INFO: Enabling GPS mode for concentrator’s counter.
Jun 23 10:37:04 rak-gateway ttn-gateway[773]: WARNING: [gps] GPS out of sync, keeping previous time reference
Jun 23 10:39:04 rak-gateway ttn-gateway[773]: WARNING: [gps] GPS out of sync, keeping previous time reference
Jun 23 10:39:04 rak-gateway ttn-gateway[773]: INFO: [down] PULL_ACK received in 106 ms
Jun 23 10:39:04 rak-gateway ttn-gateway[773]: INFO: [down] PULL_ACK received in 104 ms
Jun 23 10:39:04 rak-gateway ttn-gateway[773]: INFO: [down] PULL_ACK received in 123 ms
Jun 23 10:39:04 rak-gateway ttn-gateway[773]: ##### 2019-06-23 09:37:34 GMT #####
