eros23
(Gabriele)
1
Hi, I followed this guide.
then I modified this file:
/opt/ttn-gateway/packet_forwarder/lora_pkt_fwd/local_conf.json
“gateway_conf”: {
“gateway_ID”: “b827ebffxxxxxxxx”,
“server_address”: “router.eu.thethings.network”,
“serv_port_up”: 1700,
“serv_port_down”: 1700,
“serv_enabled”: true,
“ref_latitude”: 0,
“ref_longitude”: 0,
“ref_altitude”: 0
but in the state of my console on https://console.thethingsnetwork.org/gateways/eui-b827ebfffxxxxxx
I get the word “not connect”
Status
not connected
Frequency Plan
Europe868MHz
Router
ttn-router-eu
can anyone help me?
Fomi
(Fomi Tong)
2
Hi, @eros23
Do you only want to use it without customizing something of LoRa?
If it is, i recommend you to use our RAK2245/RAK831 RPi firmware directly, you can download the image from RAK website:
https://www.rakwireless.com/en/download/LoRa/RAK2245-Pi-HAT#Firmware
and refer to this document to use:
https://www.rakwireless.com/en/download/LoRa/RAK2245-Pi-HAT#Application-Notes
eros23
(Gabriele)
3
I have done it but it is always disconnected. where I find the lora_pkt_fwd logs.
Fomi
(Fomi Tong)
4
You can execute the following command on RPi:
tail -f /var/log/syslog | grep ttn-gateway
ZhuQI
(ZhuQI)
5
Is your id “b827ebffxxxxxxxx”?
Is “xxxxxxxx” your hidden content or is the gateway id “b827ebffxxxxxxxx”?
Hobo
(Vladislav Yordanov)
6
Hi @eros23,
Did you remember to check the box “Use legacy packet forwarder when registering the Gateway” under the Gateway EUI field ?
