All,
I build a LoRaWAN GW using the RAK2247 hat with a RPI4. The software runs smoothly when in the office. However when I install the GW in an environment with a bunch of RELAYs it hangs every once and a while.
- Software used: rak_common_gateway
- It seems to be caused due to interference and it does not recover by itself.
** Restarting the ttn-gateway.service solves the problem (for a while) - When I check the status, before restarting, of the ttn-gateway.service is say OK
I suspect the RAK2247 is hanging due to interference.
Does any of you have similar experiences? (or a solution :-))
