I want to develop a specific casing using RAK2270 version for developer; could you please give me the size of PCB flex ?
Also, if you could give me the complete reference of the thin film battery used for the sticker, this would be perfect.
Thank you for your support.
Pascal DARAGON
Hi @pasdaran ,
Size is same with the sticker - 85 mm x 118 mm
For the battery, this is the PN, voltage and capacity
Thank you Carlrowan for your prompt and precise answer
Pascal
Hi Carlrowan,
Just another question regarding the PCB for developer.
I noticed that there are 2 versions: “With Clip without Battery” and “Without Clip without Battery”.
Could you please precise what is the difference between these 2 SKUs ?
The picture to illustrate each seems to be the same.
Thanks and regards
Pascal
Hi @pasdaran ,
The clip looks like this.
It has pogo pins so you can have contact on the programming pads in the PCB and wont need to solder any wire/connection.
The perfect tool !
Best regards
Pascal
