Rak2287 configuration help
Please Help,
I bought 10 pieces of Rak2287 EU433 for raspberry-pi (as in the picture)
I installed everything (https://github.com/RAKWireless/rak_common_for_gateway). How do I configure globalconf because there is only CN433 in the setup, there is no EU433 and also in the server chirpstack network toml file?
GLOBAL CONF
“SX130x_conf”: {
“com_type”: “SPI”,
“com_path”: “/dev/spidev0.0”,
“lorawan_public”: true,
“clksrc”: 0,
“antenna_gain”: 0, /* antenna gain, in dBi /
“full_duplex”: false,
“fine_timestamp”: {
“enable”: false,
“mode”: “all_sf” /
high_capacity or all_sf */
“radio_0”: {
“enable”: true,
“type”: “SX1250”,
“single_input_mode”: true,
“freq”: 434375000,
“rssi_offset”: -207.0,
“rssi_tcomp”: {“coeff_a”: 0, “coeff_b”: 0, “coeff_c”: 20.41, “coeff_d”: 2162.56, “coeff_e”: 0},
“tx_enable”: true,
“tx_freq_min”: 433050000,
“tx_freq_max”: 434900000,
“tx_gain_lut”:[
{“rf_power”: -6, “pa_gain”: 0, “pwr_idx”: 0},
{“rf_power”: -3, “pa_gain”: 0, “pwr_idx”: 1},
{“rf_power”: 0, “pa_gain”: 0, “pwr_idx”: 2},
{“rf_power”: 3, “pa_gain”: 1, “pwr_idx”: 3},
{“rf_power”: 6, “pa_gain”: 1, “pwr_idx”: 4},
{“rf_power”: 10, “pa_gain”: 1, “pwr_idx”: 5},
{“rf_power”: 11, “pa_gain”: 1, “pwr_idx”: 6},
{“rf_power”: 12, “pa_gain”: 1, “pwr_idx”: 7},
{“rf_power”: 13, “pa_gain”: 1, “pwr_idx”: 8},
{“rf_power”: 14, “pa_gain”: 1, “pwr_idx”: 9},
{“rf_power”: 16, “pa_gain”: 1, “pwr_idx”: 10},
{“rf_power”: 20, “pa_gain”: 1, “pwr_idx”: 11},
{“rf_power”: 23, “pa_gain”: 1, “pwr_idx”: 12},
{“rf_power”: 25, “pa_gain”: 1, “pwr_idx”: 13},
{“rf_power”: 26, “pa_gain”: 1, “pwr_idx”: 14},
{“rf_power”: 27, “pa_gain”: 1, “pwr_idx”: 15}
“radio_1”: {
“enable”: true,
“type”: “SX1250”,
“freq”: 433575000,
“tx_enable”: false
“chan_multiSF_All”: {“spreading_factor_enable”: [ 5, 6, 7, 8, 9, 10, 11, 12 ]},
“chan_multiSF_0”: {“enable”: true, “radio”: 1, “if”: -300000},
“chan_multiSF_1”: {“enable”: true, “radio”: 1, “if”: -100000},
“chan_multiSF_2”: {“enable”: true, “radio”: 1, “if”: 100000},
“chan_multiSF_3”: {“enable”: true, “radio”: 1, “if”: 300000},
“chan_multiSF_4”: {“enable”: true, “radio”: 0, “if”: -300000},
“chan_multiSF_5”: {“enable”: true, “radio”: 0, “if”: -100000},
“chan_multiSF_6”: {“enable”: true, “radio”: 0, “if”: 100000},
“chan_multiSF_7”: {“enable”: true, “radio”: 0, “if”: 300000},
“chan_Lora_std”: {“enable”: false, “radio”: 1, “if”: -200000, “bandwidth”: 250000, “spread_factor”: 7,
“implicit_hdr”: false, “implicit_payload_length”: 17, “implicit_crc_en”: false, “implicit_coderate”: 1},
“chan_FSK”: {“enable”: false, “radio”: 1, “if”: 300000, “bandwidth”: 125000, “datarate”: 50000}
"gateway_conf": {
    "gateway_ID": "0000000000000000",
    /* change with default server address/ports */
"server_address": "127.0.0.1",
    "serv_port_up": 1700,
    "serv_port_down": 1700,
    /* adjust the following parameters for your network */
    "keepalive_interval": 10,
    "stat_interval": 30,
    "push_timeout_ms": 100,
    /* forward only valid packets */
    "forward_crc_valid": true,
    "forward_crc_error": false,
    "forward_crc_disabled": false,
    /* GPS configuration */
    "gps_tty_path": "/dev/ttyAMA0",
    /* GPS reference coordinates */
    "ref_latitude": 0.0,
    "ref_longitude": 0.0,
    "ref_altitude": 0,
    "autoquit_threshold": 20,
    /* Beaconing parameters */
    "beacon_period": 0, /* disable class B beacon */
    "beacon_freq_hz": 508300000,
    "beacon_freq_nb": 8,
    "beacon_freq_step": 200000,
    "beacon_datarate": 10,
    "beacon_bw_hz": 125000,
    "beacon_power": 27
"debug_conf": {
    "ref_payload":[
        {"id": "0xCAFE1234"},
        {"id": "0xCAFE2345"}
    "log_file": "loragw_hal.log"
TOML file
This configuration configures ChirpStack Network Server for the EU868 band using a MQTT
broker to communicate with the gateways. Many options and defaults have been
omitted for simplicity.
For other bands, see the ./examples/ sub-directory.
See Configuration - ChirpStack open-source LoRaWAN<sup>®</sup> Network Server for a full
configuration example and documentation.
PostgreSQL settings.
Please note that PostgreSQL 9.5+ is required.
[postgresql]
PostgreSQL dsn (e.g.: postgres://user:password@hostname/database?sslmode=disable).
Besides using an URL (e.g. ‘postgres://user:password@hostname/database?sslmode=disable’)
it is also possible to use the following format:
‘user=chirpstack_ns dbname=chirpstack_ns sslmode=disable’.
The following connection parameters are supported:
* dbname - The name of the database to connect to
* user - The user to sign in as
* password - The user’s password
* host - The host to connect to. Values that start with / are for unix domain sockets. (default is localhost)
* port - The port to bind to. (default is 5432)
* sslmode - Whether or not to use SSL (default is require, this is not the default for libpq)
* fallback_application_name - An application_name to fall back to if one isn’t provided.
* connect_timeout - Maximum wait for connection, in seconds. Zero or not specified means wait indefinitely.
* sslcert - Cert file location. The file must contain PEM encoded data.
* sslkey - Key file location. The file must contain PEM encoded data.
* sslrootcert - The location of the root certificate file. The file must contain PEM encoded data.
Valid values for sslmode are:
* disable - No SSL
* require - Always SSL (skip verification)
* verify-ca - Always SSL (verify that the certificate presented by the server was signed by a trusted CA)
* verify-full - Always SSL (verify that the certification presented by the server was signed by a trusted CA and the server host name matches the one in the certificate)
dsn=“postgres://chirpstack_ns:dbpassword@localhost/chirpstack_ns?sslmode=disable”
Redis settings
Please note that Redis 2.6.0+ is required.
[redis]
Redis url (e.g. redis://user:password@hostname/0)
For more information about the Redis URL format, see:
https://www.iana.org/assignments/uri-schemes/prov/redis
url=“redis://localhost:6379”
Network-server settings.
[network_server]
Network identifier (NetID, 3 bytes) encoded as HEX (e.g. 010203)
net_id=“000000”
LoRaWAN regional band configuration.
Note that you might want to consult the LoRaWAN Regional Parameters
specification for valid values that apply to your region.
See: https://www.lora-alliance.org/lorawan-for-developers
[network_server.band]
name=“EU433”
LoRaWAN network related settings.
[network_server.network_settings]
enabled_uplink_channels=[]
Disable ADR
When set, this globally disables ADR.
disable_adr=false
# Extra channel configuration.
# Use this for LoRaWAN regions where it is possible to extend the by default
# available channels with additional channels (e.g. the EU band).
# The first 5 channels will be configured as part of the OTAA join-response
# (using the CFList field).
# The other channels (or channel / data-rate changes) will be (re)configured
# using the NewChannelReq mac-command.
[[network_server.network_settings.extra_channels]]
frequency=867100000
min_dr=0
max_dr=5
frequency=867300000
min_dr=0
max_dr=5
frequency=867500000
min_dr=0
max_dr=5
frequency=867700000
min_dr=0
max_dr=5
frequency=867900000
min_dr=0
max_dr=5
# Class B settings
[network_server.network_settings.class_b]
# Ping-slot data-rate.
ping_slot_dr=0
# Ping-slot frequency (Hz)
# Set this to 0 to use the default frequency plan for the configured region
# (which could be frequency hopping).
ping_slot_frequency=0
Network-server API
This is the network-server API that is used by ChirpStack Application Server or other
custom components interacting with ChirpStack Network Server.
[network_server.api]
ip:port to bind the api server
bind=“0.0.0.0:8000”
Backend defines the gateway backend settings.
The gateway backend handles the communication with the gateway(s) part of
the LoRaWAN network.
[network_server.gateway.backend]
Backend
type=“mqtt”
# MQTT gateway backend settings.
# This is the backend communicating with the LoRa gateways over a MQTT broker.
[network_server.gateway.backend.mqtt]
# MQTT topic templates for the different MQTT topics.
# The meaning of these topics are documented at:
# https://www.chirpstack.io/gateway-bridge/
# The default values match the default expected configuration of the
# ChirpStack Gateway Bridge MQTT backend. Therefore only change these values when
# absolutely needed.
# Event topic template.
event_topic="gateway/+/event/+"
# Command topic template.
# Use:
#   * "{{ .GatewayID }}" as an substitution for the LoRa gateway ID
#   * "{{ .CommandType }}" as an substitution for the command type
command_topic_template="gateway/{{ .GatewayID }}/command/{{ .CommandType }}"
# MQTT server (e.g. scheme://host:port where scheme is tcp, ssl or ws)
server="tcp://localhost:1883"
# Connect with the given username (optional)
username=""
# Connect with the given password (optional)
password=""
Metrics collection settings.
[metrics]
Timezone
The timezone is used for correctly aggregating the metrics (e.g. per hour,
day or month).
Example: “Europe/Amsterdam” or “Local” for the the system’s local time zone.
timezone=“Local”
Join-server settings.
[join_server]
Default join-server settings.
This join-server will be used when resolving the JoinEUI is set to false
or as a fallback when resolving the JoinEUI fails.
[join_server.default]
hostname:port of the default join-server
This API is provided by ChirpStack Application Server.
server=“http://localhost:8003”
