From what I see in logs it look to get push and pull when I push the Button of my Dragino sensor to force it to send a Join request, I see the Blue led on few seconds on board and I see some traffics in local logs of pi (see below) but silent console in TTN both for the Dragino device and for the gw
and a netstat tells me there are two sockets connected at port 1700 of the AWS instance of eu1… so I guess it connects at TTN but doesn’t transmit anything ??
Oct 04 19:12:36 rak-gateway ttn-gateway[4123]: *** Packet Forwarder ***
Oct 04 19:12:36 rak-gateway ttn-gateway[4123]: Version: 2.0.1
Oct 04 19:12:36 rak-gateway ttn-gateway[4123]: *** SX1302 HAL library version info ***
Oct 04 19:12:36 rak-gateway ttn-gateway[4123]: Version: 2.0.1;
Oct 04 19:12:36 rak-gateway ttn-gateway[4123]: INFO: Little endian host
Oct 04 19:12:36 rak-gateway ttn-gateway[4123]: INFO: found configuration file global_conf.json, parsing it
Oct 04 19:12:36 rak-gateway ttn-gateway[4123]: INFO: global_conf.json does contain a JSON object named SX130x_conf, parsing SX1302 parameter
Oct 04 19:12:36 rak-gateway ttn-gateway[4123]: INFO: com_type SPI, com_path /dev/spidev0.0, lorawan_public 1, clksrc 0, full_duplex 0
Oct 04 19:12:36 rak-gateway ttn-gateway[4123]: INFO: antenna_gain 0 dBi
Oct 04 19:12:36 rak-gateway ttn-gateway[4123]: INFO: Configuring legacy timestamp
Oct 04 19:12:36 rak-gateway ttn-gateway[4123]: INFO: no configuration for SX1261
Oct 04 19:12:36 rak-gateway ttn-gateway[4123]: INFO: Configuring Tx Gain LUT for rf_chain 0 with 16 indexes for sx1250
Oct 04 19:12:36 rak-gateway ttn-gateway[4123]: INFO: radio 0 enabled (type SX1250), center frequency 867500000, RSSI offset -215.399994, tx
Oct 04 19:12:36 rak-gateway ttn-gateway[4123]: INFO: radio 1 enabled (type SX1250), center frequency 868500000, RSSI offset -215.399994, tx
Oct 04 19:12:36 rak-gateway ttn-gateway[4123]: INFO: Lora multi-SF channel 0> radio 1, IF -400000 Hz, 125 kHz bw, SF 5 to 12
Oct 04 19:12:36 rak-gateway ttn-gateway[4123]: INFO: Lora multi-SF channel 1> radio 1, IF -200000 Hz, 125 kHz bw, SF 5 to 12
Oct 04 19:12:36 rak-gateway ttn-gateway[4123]: INFO: Lora multi-SF channel 2> radio 1, IF 0 Hz, 125 kHz bw, SF 5 to 12
Oct 04 19:12:36 rak-gateway ttn-gateway[4123]: INFO: Lora multi-SF channel 3> radio 0, IF -400000 Hz, 125 kHz bw, SF 5 to 12
Oct 04 19:12:36 rak-gateway ttn-gateway[4123]: INFO: Lora multi-SF channel 4> radio 0, IF -200000 Hz, 125 kHz bw, SF 5 to 12
Oct 04 19:12:36 rak-gateway ttn-gateway[4123]: INFO: Lora multi-SF channel 5> radio 0, IF 0 Hz, 125 kHz bw, SF 5 to 12
Oct 04 19:12:36 rak-gateway ttn-gateway[4123]: INFO: Lora multi-SF channel 6> radio 0, IF 200000 Hz, 125 kHz bw, SF 5 to 12
Oct 04 19:12:36 rak-gateway ttn-gateway[4123]: INFO: Lora multi-SF channel 7> radio 0, IF 400000 Hz, 125 kHz bw, SF 5 to 12
Oct 04 19:12:36 rak-gateway ttn-gateway[4123]: INFO: Lora std channel> radio 1, IF -200000 Hz, 250000 Hz bw, SF 7, Explicit header
Oct 04 19:12:36 rak-gateway ttn-gateway[4123]: INFO: FSK channel> radio 1, IF 300000 Hz, 125000 Hz bw, 50000 bps datarate
Oct 04 19:12:36 rak-gateway ttn-gateway[4123]: INFO: global_conf.json does contain a JSON object named gateway_conf, parsing gateway paramet
Oct 04 19:12:36 rak-gateway ttn-gateway[4123]: INFO: gateway MAC address is configured to AA555A0000000000
Oct 04 19:12:36 rak-gateway ttn-gateway[4123]: INFO: server hostname or IP address is configured to "eu1.cloud.thethings.network"
Oct 04 19:12:36 rak-gateway ttn-gateway[4123]: INFO: upstream port is configured to "1700"
Oct 04 19:12:36 rak-gateway ttn-gateway[4123]: INFO: downstream port is configured to "1700"
Oct 04 19:12:36 rak-gateway ttn-gateway[4123]: INFO: downstream keep-alive interval is configured to 10 seconds
Oct 04 19:12:36 rak-gateway ttn-gateway[4123]: INFO: statistics display interval is configured to 30 seconds
Oct 04 19:12:36 rak-gateway ttn-gateway[4123]: INFO: upstream PUSH_DATA time-out is configured to 100 ms
Oct 04 19:12:36 rak-gateway ttn-gateway[4123]: INFO: packets received with a valid CRC will be forwarded
Oct 04 19:12:36 rak-gateway ttn-gateway[4123]: INFO: packets received with a CRC error will NOT be forwarded
Oct 04 19:12:36 rak-gateway ttn-gateway[4123]: INFO: packets received with no CRC will NOT be forwarded
Oct 04 19:12:36 rak-gateway ttn-gateway[4123]: INFO: GPS serial port path is configured to "/dev/ttyAMA0"
Oct 04 19:12:36 rak-gateway ttn-gateway[4123]: INFO: Reference latitude is configured to 0.000000 deg
Oct 04 19:12:36 rak-gateway ttn-gateway[4123]: INFO: Reference longitude is configured to 0.000000 deg
Oct 04 19:12:36 rak-gateway ttn-gateway[4123]: INFO: Reference altitude is configured to 0 meters
Oct 04 19:12:36 rak-gateway ttn-gateway[4123]: INFO: Beaconing period is configured to 0 seconds
Oct 04 19:12:36 rak-gateway ttn-gateway[4123]: INFO: Beaconing signal will be emitted at 869525000 Hz
Oct 04 19:12:36 rak-gateway ttn-gateway[4123]: INFO: Beaconing channel number is set to 1
Oct 04 19:12:36 rak-gateway ttn-gateway[4123]: INFO: Beaconing channel frequency step is set to 0Hz
Oct 04 19:12:36 rak-gateway ttn-gateway[4123]: INFO: Beaconing datarate is set to SF9
Oct 04 19:12:36 rak-gateway ttn-gateway[4123]: INFO: Beaconing modulation bandwidth is set to 125000Hz
Oct 04 19:12:36 rak-gateway ttn-gateway[4123]: INFO: Beaconing TX power is set to 27dBm
Oct 04 19:12:36 rak-gateway ttn-gateway[4123]: INFO: global_conf.json does contain a JSON object named debug_conf, parsing debug parameters
Oct 04 19:12:36 rak-gateway ttn-gateway[4123]: INFO: got 2 debug reference payload
Oct 04 19:12:36 rak-gateway ttn-gateway[4123]: INFO: reference payload ID 0 is 0xCAFE1234
Oct 04 19:12:36 rak-gateway ttn-gateway[4123]: INFO: reference payload ID 1 is 0xCAFE2345
Oct 04 19:12:36 rak-gateway ttn-gateway[4123]: INFO: setting debug log file name to loragw_hal.log
Oct 04 19:12:36 rak-gateway ttn-gateway[4123]: INFO: found configuration file local_conf.json, parsing it
Oct 04 19:12:36 rak-gateway ttn-gateway[4123]: INFO: local_conf.json does contain a JSON object named gateway_conf, parsing gateway paramete
Oct 04 19:12:36 rak-gateway ttn-gateway[4123]: INFO: gateway MAC address is configured to DCA632FFFE023A47
Oct 04 19:12:36 rak-gateway ttn-gateway[4123]: INFO: [main] TTY port /dev/ttyAMA0 open for GPS synchronization
Oct 04 19:12:36 rak-gateway ttn-gateway[4123]: Opening SPI communication interface
Oct 04 19:12:36 rak-gateway ttn-gateway[4123]: Note: chip version is 0x10 (v1.0)
Oct 04 19:12:36 rak-gateway ttn-gateway[4123]: INFO: using legacy timestamp
Oct 04 19:12:36 rak-gateway ttn-gateway[4123]: INFO: LoRa Service modem: configuring preamble size to 8 symbols
Oct 04 19:12:36 rak-gateway ttn-gateway[4123]: ARB: dual demodulation disabled for all SF
Oct 04 19:12:36 rak-gateway ttn-gateway[4123]: INFO: found temperature sensor on port 0x39
Oct 04 19:12:36 rak-gateway ttn-gateway[4123]: INFO: [main] concentrator started, packet can now be received
Oct 04 19:12:36 rak-gateway ttn-gateway[4123]: INFO: concentrator EUI: 0x0016c001ff1a0663
Oct 04 19:12:36 rak-gateway ttn-gateway[4123]: WARNING: [gps] GPS out of sync, keeping previous time reference
Oct 04 19:12:36 rak-gateway ttn-gateway[4123]: INFO: [modify_os_time] local_time=1633371156, gps_time=1633371155
Oct 04 19:12:45 rak-gateway sudo[4251]: pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/usr/bin/systemctl status ttn-gateway.serv
Oct 04 19:12:45 rak-gateway sudo[4251]: pam_unix(sudo:session): session opened for user root by pi(uid=0)
Oct 04 19:12:45 rak-gateway sudo[4251]: pam_unix(sudo:session): session closed for user root
Oct 04 19:13:14 rak-gateway sudo[4424]: pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/usr/bin/systemctl status ttn-gateway.serv
Oct 04 19:13:14 rak-gateway sudo[4424]: pam_unix(sudo:session): session opened for user root by pi(uid=0)
Oct 04 19:13:14 rak-gateway sudo[4424]: pam_unix(sudo:session): session closed for user root
Oct 04 19:13:16 rak-gateway sudo[4439]: pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/usr/bin/systemctl status ttn-gateway.serv
Oct 04 19:13:16 rak-gateway sudo[4439]: pam_unix(sudo:session): session opened for user root by pi(uid=0)
Oct 04 19:13:16 rak-gateway sudo[4439]: pam_unix(sudo:session): session closed for user root
Oct 04 19:13:39 rak-gateway ttn-gateway[4123]: INFO: [modify_os_time] The difference between the system time(1633371156) and the GPS time(16
Oct 04 19:13:39 rak-gateway ttn-gateway[4123]: INFO: [down] PULL_ACK received in 32 ms
Oct 04 19:13:39 rak-gateway ttn-gateway[4123]: INFO: [down] PULL_ACK received in 31 ms
Oct 04 19:13:39 rak-gateway ttn-gateway[4123]: ##### 2021-10-04 18:13:06 GMT #####
Oct 04 19:13:39 rak-gateway ttn-gateway[4123]: ### [UPSTREAM] ###
Oct 04 19:13:39 rak-gateway ttn-gateway[4123]: # RF packets received by concentrator: 0
Oct 04 19:13:39 rak-gateway ttn-gateway[4123]: # CRC_OK: 0.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
Oct 04 19:13:39 rak-gateway ttn-gateway[4123]: # RF packets forwarded: 0 (0 bytes)
Oct 04 19:13:39 rak-gateway ttn-gateway[4123]: # PUSH_DATA datagrams sent: 0 (0 bytes)
Oct 04 19:13:39 rak-gateway ttn-gateway[4123]: # PUSH_DATA acknowledged: 0.00%
Oct 04 19:13:39 rak-gateway ttn-gateway[4123]: ### [DOWNSTREAM] ###
Oct 04 19:13:39 rak-gateway ttn-gateway[4123]: # PULL_DATA sent: 3 (100.00% acknowledged)
Oct 04 19:13:39 rak-gateway ttn-gateway[4123]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Oct 04 19:13:39 rak-gateway ttn-gateway[4123]: # RF packets sent to concentrator: 0 (0 bytes)
Oct 04 19:13:39 rak-gateway ttn-gateway[4123]: # TX errors: 0
Oct 04 19:13:39 rak-gateway ttn-gateway[4123]: ### SX1302 Status ###
Oct 04 19:13:39 rak-gateway ttn-gateway[4123]: # SX1302 counter (INST): 30787848
Oct 04 19:13:39 rak-gateway ttn-gateway[4123]: # SX1302 counter (PPS): 0
Oct 04 19:13:39 rak-gateway ttn-gateway[4123]: # BEACON queued: 0
Oct 04 19:13:39 rak-gateway ttn-gateway[4123]: # BEACON sent so far: 0
Oct 04 19:13:39 rak-gateway ttn-gateway[4123]: # BEACON rejected: 0
Oct 04 19:13:39 rak-gateway ttn-gateway[4123]: ### [JIT] ###
Oct 04 19:13:39 rak-gateway ttn-gateway[4123]: src/jitqueue.c:440:jit_print_queue(): INFO: [jit] queue is empty
Oct 04 19:13:39 rak-gateway ttn-gateway[4123]: #--------
Oct 04 19:13:39 rak-gateway ttn-gateway[4123]: ### [GPS] ###
Oct 04 19:13:39 rak-gateway ttn-gateway[4123]: # Valid time reference (age: 0 sec)
Oct 04 19:13:39 rak-gateway ttn-gateway[4123]: # no valid GPS coordinates available yet
Oct 04 19:13:39 rak-gateway ttn-gateway[4123]: ##### END #####
Oct 04 19:13:39 rak-gateway ttn-gateway[4123]: JSON up: {"stat":{"time":"2021-10-04 18:13:06 GMT","rxnb":0,"rxok":0,"rxfw":0,"ackr":0.0,"dwn
Oct 04 19:13:39 rak-gateway ttn-gateway[4123]: INFO: [up] PUSH_ACK received in 32 ms
Oct 04 19:13:39 rak-gateway ttn-gateway[4123]: INFO: Received pkt from mote: 264C4527 (fcnt=31333)
Oct 04 19:13:39 rak-gateway ttn-gateway[4123]: JSON up: {"rxpk":[{"jver":1,"tmst":36056089,"time":"2021-10-04T18:13:46.056089Z","tmms":13174
Oct 04 19:13:39 rak-gateway ttn-gateway[4123]: INFO: [up] PUSH_ACK received in 31 ms
Oct 04 19:13:39 rak-gateway ttn-gateway[4123]: JSON up: {"rxpk":[{"jver":1,"tmst":43094516,"time":"2021-10-04T18:14:00.094515Z","tmms":13174
Oct 04 19:13:39 rak-gateway ttn-gateway[4123]: JSON up: {"rxpk":[{"jver":1,"tmst":50133920,"time":"2021-10-04T18:14:14.133920Z","tmms":13174
Oct 04 19:13:39 rak-gateway ttn-gateway[4123]: JSON up: {"rxpk":[{"jver":1,"tmst":57173324,"time":"2021-10-04T18:14:28.173324Z","tmms":13174
Oct 04 19:13:39 rak-gateway ttn-gateway[4123]: ##### 2021-10-04 18:13:36 GMT #####
Oct 04 19:13:39 rak-gateway ttn-gateway[4123]: # RF packets received by concentrator: 4
Oct 04 19:13:39 rak-gateway ttn-gateway[4123]: # CRC_OK: 100.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
Oct 04 19:13:39 rak-gateway ttn-gateway[4123]: # RF packets forwarded: 4 (92 bytes)
Oct 04 19:13:39 rak-gateway ttn-gateway[4123]: # PUSH_DATA datagrams sent: 5 (1342 bytes)
Oct 04 19:13:39 rak-gateway ttn-gateway[4123]: # PUSH_DATA acknowledged: 100.00%
Oct 04 19:13:39 rak-gateway ttn-gateway[4123]: # SX1302 counter (INST): 60788286
Oct 04 19:13:39 rak-gateway ttn-gateway[4123]: JSON up: {"stat":{"time":"2021-10-04 18:13:36 GMT","rxnb":4,"rxok":4,"rxfw":4,"ackr":100.0,"d
Oct 04 19:14:33 rak-gateway ttn-gateway[4123]: JSON up: {"rxpk":[{"jver":1,"tmst":64212733,"time":"2021-10-04T18:14:42.212733Z","tmms":13174
Oct 04 19:14:33 rak-gateway ttn-gateway[4123]: INFO: [up] PUSH_ACK received in 31 ms
Oct 04 19:14:33 rak-gateway ttn-gateway[4123]: INFO: Received pkt from mote: 264C4527 (fcnt=31333)
Oct 04 19:14:33 rak-gateway ttn-gateway[4123]: JSON up: {"rxpk":[{"jver":1,"tmst":71252128,"time":"2021-10-04T18:14:56.252127Z","tmms":13174
Oct 04 19:14:33 rak-gateway ttn-gateway[4123]: INFO: [down] PULL_ACK received in 31 ms
Oct 04 19:14:33 rak-gateway ttn-gateway[4123]: JSON up: {"rxpk":[{"jver":1,"tmst":78291503,"time":"2021-10-04T18:15:10.291503Z","tmms":13174
Oct 04 19:14:33 rak-gateway ttn-gateway[4123]: INFO: [up] PUSH_ACK received in 30 ms
Oct 04 19:14:33 rak-gateway ttn-gateway[4123]: INFO: [down] PULL_ACK received in 28 ms
Oct 04 19:14:33 rak-gateway ttn-gateway[4123]: JSON up: {"rxpk":[{"jver":1,"tmst":85382369,"time":"2021-10-04T18:15:24.382368Z","tmms":13174
Oct 04 19:14:33 rak-gateway ttn-gateway[4123]: INFO: [up] PUSH_ACK received in 33 ms
Oct 04 19:14:33 rak-gateway ttn-gateway[4123]: ##### 2021-10-04 18:14:06 GMT #####
Oct 04 19:14:33 rak-gateway ttn-gateway[4123]: ### [UPSTREAM] ###
Oct 04 19:14:33 rak-gateway ttn-gateway[4123]: # RF packets received by concentrator: 4
Oct 04 19:14:33 rak-gateway ttn-gateway[4123]: # CRC_OK: 100.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
Oct 04 19:14:33 rak-gateway ttn-gateway[4123]: # RF packets forwarded: 4 (92 bytes)
Oct 04 19:14:33 rak-gateway ttn-gateway[4123]: # PUSH_DATA datagrams sent: 5 (1344 bytes)
Oct 04 19:14:33 rak-gateway ttn-gateway[4123]: # PUSH_DATA acknowledged: 100.00%
Oct 04 19:14:33 rak-gateway ttn-gateway[4123]: ### [DOWNSTREAM] ###
Oct 04 19:14:33 rak-gateway ttn-gateway[4123]: # PULL_DATA sent: 3 (100.00% acknowledged)
Oct 04 19:14:33 rak-gateway ttn-gateway[4123]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Oct 04 19:14:33 rak-gateway ttn-gateway[4123]: # RF packets sent to concentrator: 0 (0 bytes)
Oct 04 19:14:33 rak-gateway ttn-gateway[4123]: # TX errors: 0
Oct 04 19:14:33 rak-gateway ttn-gateway[4123]: ### SX1302 Status ###
Oct 04 19:14:33 rak-gateway ttn-gateway[4123]: # SX1302 counter (INST): 90788727
Oct 04 19:14:33 rak-gateway ttn-gateway[4123]: # SX1302 counter (PPS): 0
Oct 04 19:14:33 rak-gateway ttn-gateway[4123]: # BEACON queued: 0
Oct 04 19:14:33 rak-gateway ttn-gateway[4123]: # BEACON sent so far: 0
Oct 04 19:14:33 rak-gateway ttn-gateway[4123]: # BEACON rejected: 0
Oct 04 19:14:33 rak-gateway ttn-gateway[4123]: ### [JIT] ###
Oct 04 19:14:33 rak-gateway ttn-gateway[4123]: src/jitqueue.c:440:jit_print_queue(): INFO: [jit] queue is empty
Oct 04 19:14:33 rak-gateway ttn-gateway[4123]: #--------
Oct 04 19:14:33 rak-gateway ttn-gateway[4123]: ### [GPS] ###
Oct 04 19:14:33 rak-gateway ttn-gateway[4123]: # Valid time reference (age: 0 sec)
Oct 04 19:14:33 rak-gateway ttn-gateway[4123]: # no valid GPS coordinates available yet
Oct 04 19:14:33 rak-gateway ttn-gateway[4123]: ##### END #####
Oct 04 19:14:33 rak-gateway ttn-gateway[4123]: JSON up: {"stat":{"time":"2021-10-04 18:14:06 GMT","rxnb":4,"rxok":4,"rxfw":4,"ackr":100.0,"d
Oct 04 19:14:33 rak-gateway ttn-gateway[4123]: INFO: [down] PULL_ACK received in 29 ms
Oct 04 19:14:33 rak-gateway ttn-gateway[4123]: JSON up: {"rxpk":[{"jver":1,"tmst":96769919,"time":"2021-10-04T18:15:47.769919Z","tmms":13174
Oct 04 19:14:33 rak-gateway ttn-gateway[4123]: JSON up: {"rxpk":[{"jver":1,"tmst":103808343,"time":"2021-10-04T18:16:01.808342Z","tmms":1317
Oct 04 19:14:33 rak-gateway ttn-gateway[4123]: INFO: [up] PUSH_ACK received in 32 ms
Oct 04 19:14:33 rak-gateway ttn-gateway[4123]: JSON up: {"rxpk":[{"jver":1,"tmst":110847719,"time":"2021-10-04T18:16:15.847718Z","tmms":1317
pi@rak-gateway:~ $
