RAK2287 not receiving any RF packets... why?
Issue: RAK2287, US915, No RF packets received from end devices
Setup:
I have a RAK2287 (SPI, US915) connected to Raspberry PI 3B+, running RAK code for packet_forwarder.
The lora_pkt_fwd program starts up and begins talking to my chripstack-gateway-bridge, but it never receives any packets from end devices.
I have an end device RAK4631 programmed to join and send on US915 band also. I tested this end-device against a RAK2245 connected to same Raspberry Pi, previously, and it worked with no issues.
Then I simply powered off the PI, disconnected the RAK2245, connected the RAK2287, and downloaded the RAK github files for RAK2287 and compiled, edited the global_conf.json for US915 and the same gateway ID, then ran ./rak_common_for_gateway_lora/rak2287/packet_forwarder/lora_pkt_fwd
Here is global_conf.json:
(I left local_conf.json empty and did all config in global_conf.json for this test.)
    "SX130x_conf": {
        "com_type": "SPI",
        "com_path": "/dev/spidev0.0",
        "lorawan_public": true,
        "clksrc": 0,
        "antenna_gain": 0, /* antenna gain, in dBi */
        "full_duplex": false,
        "fine_timestamp": {
            "enable": false,
            "mode": "all_sf" /* high_capacity or all_sf */
        "sx1261_conf": {
            "spi_path": "/dev/spidev0.1",
            "rssi_offset": 0, /* dB */
            "spectral_scan": {
                "enable": false,
                "freq_start": 903900000,
                "nb_chan": 8,
                "nb_scan": 2000,
                "pace_s": 10
            "lbt": {
                "enable": false /* LBT for 500 Khz channels is not supported */
        "radio_0": {
            "enable": true,
            "type": "SX1250",
            "freq": 904300000,
            "rssi_offset": -215.4,
            "rssi_tcomp": {"coeff_a": 0, "coeff_b": 0, "coeff_c": 20.41, "coeff_d": 2162.56, "coeff_e": 0},
            "tx_enable": true,
            "tx_freq_min": 923000000,
            "tx_freq_max": 928000000,
            "tx_gain_lut":[
                {"rf_power": 12, "pa_gain": 0, "pwr_idx": 15},
                {"rf_power": 13, "pa_gain": 0, "pwr_idx": 16},
                {"rf_power": 14, "pa_gain": 0, "pwr_idx": 17},
                {"rf_power": 15, "pa_gain": 0, "pwr_idx": 19},
                {"rf_power": 16, "pa_gain": 0, "pwr_idx": 20},
                {"rf_power": 17, "pa_gain": 0, "pwr_idx": 22},
                {"rf_power": 18, "pa_gain": 1, "pwr_idx": 1},
                {"rf_power": 19, "pa_gain": 1, "pwr_idx": 2},
                {"rf_power": 20, "pa_gain": 1, "pwr_idx": 3},
                {"rf_power": 21, "pa_gain": 1, "pwr_idx": 4},
                {"rf_power": 22, "pa_gain": 1, "pwr_idx": 5},
                {"rf_power": 23, "pa_gain": 1, "pwr_idx": 6},
                {"rf_power": 24, "pa_gain": 1, "pwr_idx": 7},
                {"rf_power": 25, "pa_gain": 1, "pwr_idx": 9},
                {"rf_power": 26, "pa_gain": 1, "pwr_idx": 11},
                {"rf_power": 27, "pa_gain": 1, "pwr_idx": 14}
        "radio_1": {
            "enable": true,
            "type": "SX1250",
            "freq": 905000000,
            "tx_enable": false
        "chan_multiSF_All": {"spreading_factor_enable": [ 5, 6, 7, 8, 9, 10, 11, 12 ]},
        "chan_multiSF_0": {"enable": true, "radio": 0, "if": -400000},  /* Freq : 903.9 MHz*/
        "chan_multiSF_1": {"enable": true, "radio": 0, "if": -200000},  /* Freq : 904.1 MHz*/
        "chan_multiSF_2": {"enable": true, "radio": 0, "if":  0},       /* Freq : 904.3 MHz*/
        "chan_multiSF_3": {"enable": true, "radio": 0, "if":  200000},  /* Freq : 904.5 MHz*/
        "chan_multiSF_4": {"enable": true, "radio": 1, "if": -300000},  /* Freq : 904.7 MHz*/
        "chan_multiSF_5": {"enable": true, "radio": 1, "if": -100000},  /* Freq : 904.9 MHz*/
        "chan_multiSF_6": {"enable": true, "radio": 1, "if":  100000},  /* Freq : 905.1 MHz*/
        "chan_multiSF_7": {"enable": true, "radio": 1, "if":  300000},  /* Freq : 905.3 MHz*/
        "chan_Lora_std":  {"enable": true, "radio": 0, "if":  300000, "bandwidth": 500000, "spread_factor": 8,                                          /* Freq : 904.6 MHz*/
                           "implicit_hdr": false, "implicit_payload_length": 17, "implicit_crc_en": false, "implicit_coderate": 1},
        "chan_FSK":       {"enable": false, "radio": 1, "if":  300000, "bandwidth": 125000, "datarate": 50000}                                          /* Freq : 868.8 MHz*/
    "gateway_conf": {
        "gateway_ID": "2323232323232301",
        /* change with default server address/ports */
        "server_address": "localhost",
        "serv_port_up": 1700,
        "serv_port_down": 1700,
        /* adjust the following parameters for your network */
        "keepalive_interval": 10,
        "stat_interval": 30,
        "push_timeout_ms": 100,
        /* forward only valid packets */
        "forward_crc_valid": true,
        "forward_crc_error": false,
        "forward_crc_disabled": false,
        /* GPS configuration */
        /* "gps_tty_path": "/dev/ttyS0", */
        /* GPS reference coordinates */
        "ref_latitude": 0.0,
        "ref_longitude": 0.0,
        "ref_altitude": 0,
        /* Beaconing parameters */
        "beacon_period": 0, /* disable class B beacon */
        "beacon_freq_hz": 869525000,
        "beacon_datarate": 9,
        "beacon_bw_hz": 125000,
        "beacon_power": 14,
        "beacon_infodesc": 0
    "debug_conf": {
        "ref_payload":[
            {"id": "0xCAFE1234"},
            {"id": "0xCAFE2345"}
        "log_file": "loragw_hal.log"
Here is output from lora_pkt_fwd command:
./lora_pkt_fwd
*** Packet Forwarder ***
Version: 2.0.1
*** SX1302 HAL library version info ***
Version: 2.0.1;
INFO: Little endian host
INFO: found configuration file global_conf.json, parsing it
INFO: global_conf.json does contain a JSON object named SX130x_conf, parsing SX1302 parameters
INFO: com_type SPI, com_path /dev/spidev0.0, lorawan_public 1, clksrc 0, full_duplex 0
INFO: antenna_gain 0 dBi
INFO: Configuring legacy timestamp
INFO: Configuring Tx Gain LUT for rf_chain 0 with 16 indexes for sx1250
INFO: radio 0 enabled (type SX1250), center frequency 904300000, RSSI offset -215.399994, tx enabled 1, single input mode 0
INFO: radio 1 enabled (type SX1250), center frequency 905000000, RSSI offset -215.399994, tx enabled 0, single input mode 0
INFO: Lora multi-SF channel 0>  radio 0, IF -400000 Hz, 125 kHz bw, SF 5 to 12
INFO: Lora multi-SF channel 1>  radio 0, IF -200000 Hz, 125 kHz bw, SF 5 to 12
INFO: Lora multi-SF channel 2>  radio 0, IF 0 Hz, 125 kHz bw, SF 5 to 12
INFO: Lora multi-SF channel 3>  radio 0, IF 200000 Hz, 125 kHz bw, SF 5 to 12
INFO: Lora multi-SF channel 4>  radio 1, IF -300000 Hz, 125 kHz bw, SF 5 to 12
INFO: Lora multi-SF channel 5>  radio 1, IF -100000 Hz, 125 kHz bw, SF 5 to 12
INFO: Lora multi-SF channel 6>  radio 1, IF 100000 Hz, 125 kHz bw, SF 5 to 12
INFO: Lora multi-SF channel 7>  radio 1, IF 300000 Hz, 125 kHz bw, SF 5 to 12
INFO: Lora std channel> radio 0, IF 300000 Hz, 500000 Hz bw, SF 8, Explicit header
INFO: FSK channel 8 disabled
INFO: global_conf.json does contain a JSON object named gateway_conf, parsing gateway parameters
INFO: gateway MAC address is configured to 2323232323232301
INFO: server hostname or IP address is configured to "localhost"
INFO: upstream port is configured to "1700"
INFO: downstream port is configured to "1700"
INFO: downstream keep-alive interval is configured to 10 seconds
INFO: statistics display interval is configured to 30 seconds
INFO: upstream PUSH_DATA time-out is configured to 100 ms
INFO: Reference latitude is configured to 0.000000 deg
INFO: Reference longitude is configured to 0.000000 deg
INFO: Reference altitude is configured to 0 meters
INFO: Beaconing period is configured to 0 seconds
INFO: Beaconing signal will be emitted at 869525000 Hz
INFO: Beaconing datarate is set to SF9
INFO: Beaconing modulation bandwidth is set to 125000Hz
INFO: Beaconing TX power is set to 14dBm
INFO: Beaconing information descriptor is set to 0
INFO: global_conf.json does contain a JSON object named debug_conf, parsing debug parameters
INFO: got 2 debug reference payload
INFO: reference payload ID 0 is 0xCAFE1234
INFO: reference payload ID 1 is 0xCAFE2345
INFO: setting debug log file name to loragw_hal.log
INFO: found configuration file local_conf.json, parsing it
INFO: local_conf.json does contain a JSON object named gateway_conf, parsing gateway parameters
CoreCell reset through GPIO17...
Opening SPI communication interface
Note: chip version is 0x10 (v1.0)
INFO: using legacy timestamp
INFO: LoRa Service modem: configuring preamble size to 8 symbols
ARB: dual demodulation disabled for all SF
INFO: [main] concentrator started, packet can now be received
INFO: concentrator EUI: 0x0016c001ff19cd6b
INFO: [down] PULL_ACK received in 0 ms
##### 2022-01-07 20:56:28 GMT #####
### [UPSTREAM] ###
# RF packets received by concentrator: 0
# CRC_OK: 0.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
# RF packets forwarded: 0 (0 bytes)
# PUSH_DATA datagrams sent: 0 (0 bytes)
# PUSH_DATA acknowledged: 0.00%
### [DOWNSTREAM] ###
# PULL_DATA sent: 3 (100.00% acknowledged)
# PULL_RESP(onse) datagrams received: 0 (0 bytes)
# RF packets sent to concentrator: 0 (0 bytes)
# TX errors: 0
### SX1302 Status ###
# SX1302 counter (INST): 134217728
# SX1302 counter (PPS):  0
# BEACON queued: 0
# BEACON sent so far: 0
# BEACON rejected: 0
### [JIT] ###
src/jitqueue.c:440:jit_print_queue(): INFO: [jit] queue is empty
### [GPS] ###
# GPS sync is disabled
##### END #####
JSON up: {"stat":{"time":"2022-01-07 20:56:28 GMT","rxnb":0,"rxok":0,"rxfw":0,"ackr":0.0,"dwnb":0,"txnb":0,"temp":0.0}}
INFO: [up] PUSH_ACK received in 0 ms
I am grateful for any assistance.
i have same problem. did you solved?
