Issue: I am not seeing my gateway connect to TTN
Setup: Standard 2287 with the pi hat and a pi 4
Server: Latest firmware downloaded this week
Details: Hi all. I have read every thread on here and other forums that seem related and I cannot seem to diagnose my fault, sorry if I have missed something obvious.
From the TTN side of things I’m certain my ID is set correctly, and I have tried with the authenticated connection ticked and unticked. I’m not sure you can get much else wrong there.
On the 2287 it boots cleanly, and if I run host eu1.cloud.thethings.network originally it wouldn’t resolve. I have set up a DNS server in /etc/resolvconf.conf and now host returns the correct IPs. I also set static domain_name_servers=8.8.8.8 in /etc/dhcpcp.conf which I saw in another thread with a similar problem.
My logs show afaik it working, with ACK which I assume is the server getting my request?
These are ttn gateway logs from a clean boot
May 04 20:58:27 rak-gateway ttn-gateway[532]: Opening SPI communication interface
May 04 20:58:27 rak-gateway ttn-gateway[532]: Note: chip version is 0x10 (v1.0)
May 04 20:58:27 rak-gateway ttn-gateway[532]: INFO: using legacy timestamp
May 04 20:58:27 rak-gateway ttn-gateway[532]: INFO: LoRa Service modem: configuring preamble size to 8 symbols
May 04 20:58:27 rak-gateway ttn-gateway[532]: ARB: dual demodulation disabled for all SF
May 04 20:58:27 rak-gateway ttn-gateway[532]: INFO: found temperature sensor on port 0x39
May 04 20:58:27 rak-gateway ttn-gateway[532]: INFO: [main] concentrator started, packet can now be received
May 04 20:58:27 rak-gateway ttn-gateway[532]: INFO: concentrator EUI: 0x0016c001f10ce556
May 04 20:58:27 rak-gateway ttn-gateway[532]: WARNING: [gps] GPS out of sync, keeping previous time reference
May 04 20:58:27 rak-gateway ttn-gateway[532]: INFO: [modify_os_time] local_time=1683230307, gps_time=1683230310
May 04 21:00:40 rak-gateway ttn-gateway[532]: INFO: [modify_os_time] The difference between the system time(1683230307) and the GPS time(1683230310) is less than 10 seconds. Use the system time.
May 04 21:00:40 rak-gateway ttn-gateway[532]: INFO: [down] PULL_ACK received in 46 ms
May 04 21:00:40 rak-gateway ttn-gateway[532]: INFO: [down] PULL_ACK received in 41 ms
May 04 21:00:40 rak-gateway ttn-gateway[532]: INFO: [down] PULL_ACK received in 47 ms
May 04 21:00:40 rak-gateway ttn-gateway[532]: ##### 2023-05-04 19:59:10 GMT #####
May 04 21:00:40 rak-gateway ttn-gateway[532]: ### [UPSTREAM] ###
May 04 21:00:40 rak-gateway ttn-gateway[532]: # RF packets received by concentrator: 0
May 04 21:00:40 rak-gateway ttn-gateway[532]: # CRC_OK: 0.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
May 04 21:00:40 rak-gateway ttn-gateway[532]: # RF packets forwarded: 0 (0 bytes)
May 04 21:00:40 rak-gateway ttn-gateway[532]: # PUSH_DATA datagrams sent: 0 (0 bytes)
May 04 21:00:40 rak-gateway ttn-gateway[532]: # PUSH_DATA acknowledged: 0.00%
May 04 21:00:40 rak-gateway ttn-gateway[532]: ### [DOWNSTREAM] ###
May 04 21:00:40 rak-gateway ttn-gateway[532]: # PULL_DATA sent: 3 (100.00% acknowledged)
May 04 21:00:40 rak-gateway ttn-gateway[532]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
May 04 21:00:40 rak-gateway ttn-gateway[532]: # RF packets sent to concentrator: 0 (0 bytes)
May 04 21:00:40 rak-gateway ttn-gateway[532]: # TX errors: 0
May 04 21:00:40 rak-gateway ttn-gateway[532]: ### SX1302 Status ###
May 04 21:00:40 rak-gateway ttn-gateway[532]: # SX1302 counter (INST): 30903159
May 04 21:00:40 rak-gateway ttn-gateway[532]: # SX1302 counter (PPS): 30282157
May 04 21:00:40 rak-gateway ttn-gateway[532]: # BEACON queued: 0
May 04 21:00:40 rak-gateway ttn-gateway[532]: # BEACON sent so far: 0
May 04 21:00:40 rak-gateway ttn-gateway[532]: # BEACON rejected: 0
May 04 21:00:40 rak-gateway ttn-gateway[532]: ### [JIT] ###
May 04 21:00:40 rak-gateway ttn-gateway[532]: src/jitqueue.c:440:jit_print_queue(): INFO: [jit] queue is empty
May 04 21:00:40 rak-gateway ttn-gateway[532]: #--------
May 04 21:00:40 rak-gateway ttn-gateway[532]: ### [GPS] ###
May 04 21:00:40 rak-gateway ttn-gateway[532]: # Valid time reference (age: 0 sec)
May 04 21:00:40 rak-gateway ttn-gateway[532]: # GPS coordinates: latitude XX.XXXXX, longitude XX.XXXXX, altitude 54 m
May 04 21:00:40 rak-gateway ttn-gateway[532]: ##### END #####
May 04 21:00:40 rak-gateway ttn-gateway[532]: JSON up: {"stat":{"time":"2023-05-04 19:59:10 GMT","lati":XX.XXXXX,"long":XX.XXXXX,"alti":54,"rxnb":0,"rxok":0,"rxfw":0,"ackr":0.0,"dwnb":0,"txnb":0,"temp":0.0}}
May 04 21:00:40 rak-gateway ttn-gateway[532]: INFO: [up] PUSH_ACK received in 54 ms
May 04 21:00:40 rak-gateway ttn-gateway[532]: INFO: [down] PULL_ACK received in 38 ms
May 04 21:00:40 rak-gateway ttn-gateway[532]: INFO: [down] PULL_ACK received in 44 ms
May 04 21:00:40 rak-gateway ttn-gateway[532]: INFO: [down] PULL_ACK received in 61 ms
May 04 21:00:40 rak-gateway ttn-gateway[532]: ##### 2023-05-04 19:59:40 GMT #####
May 04 21:00:40 rak-gateway ttn-gateway[532]: # PUSH_DATA datagrams sent: 1 (164 bytes)
May 04 21:00:40 rak-gateway ttn-gateway[532]: # PUSH_DATA acknowledged: 100.00%
May 04 21:00:40 rak-gateway ttn-gateway[532]: # SX1302 counter (INST): 60906349
May 04 21:00:40 rak-gateway ttn-gateway[532]: # SX1302 counter (PPS): 60282162
May 04 21:00:40 rak-gateway ttn-gateway[532]: JSON up: {"stat":{"time":"2023-05-04 19:59:40 GMT","lati":XX.XXXXX,"long":XX.XXXXX,"alti":54,"rxnb":0,"rxok":0,"rxfw":0,"ackr":100.0,"dwnb":0,"txnb":0,"temp":0.0}}
May 04 21:00:40 rak-gateway ttn-gateway[532]: INFO: [up] PUSH_ACK received in 74 ms
May 04 21:00:40 rak-gateway ttn-gateway[532]: INFO: [down] PULL_ACK received in 88 ms
May 04 21:00:40 rak-gateway ttn-gateway[532]: INFO: [down] PULL_ACK received in 36 ms
May 04 21:00:40 rak-gateway ttn-gateway[532]: ##### 2023-05-04 20:00:10 GMT #####
May 04 21:00:40 rak-gateway ttn-gateway[532]: # PUSH_DATA datagrams sent: 1 (166 bytes)
May 04 21:00:40 rak-gateway ttn-gateway[532]: # SX1302 counter (INST): 90908124
May 04 21:00:40 rak-gateway ttn-gateway[532]: # SX1302 counter (PPS): 90282167
May 04 21:00:40 rak-gateway ttn-gateway[532]: # GPS coordinates: latitude XX.XXXXX, longitude XX.XXXXX, altitude 51 m
May 04 21:00:40 rak-gateway ttn-gateway[532]: JSON up: {"stat":{"time":"2023-05-04 20:00:10 GMT","lati":XX.XXXXX,"long":XX.XXXXX,"alti":51,"rxnb":0,"rxok":0,"rxfw":0,"ackr":100.0,"dwnb":0,"txnb":0,"temp":0.0}}
May 04 21:00:40 rak-gateway ttn-gateway[532]: INFO: [down] PULL_ACK received in 48 ms
May 04 21:00:40 rak-gateway ttn-gateway[532]: INFO: [down] PULL_ACK received in 39 ms
May 04 21:00:40 rak-gateway ttn-gateway[532]: ##### 2023-05-04 20:00:40 GMT #####
May 04 21:02:10 rak-gateway ttn-gateway[532]: # PUSH_DATA acknowledged: 100.00%
May 04 21:02:10 rak-gateway ttn-gateway[532]: ### [DOWNSTREAM] ###
May 04 21:02:10 rak-gateway ttn-gateway[532]: # PULL_DATA sent: 3 (100.00% acknowledged)
May 04 21:02:10 rak-gateway ttn-gateway[532]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
May 04 21:02:10 rak-gateway ttn-gateway[532]: # RF packets sent to concentrator: 0 (0 bytes)
May 04 21:02:10 rak-gateway ttn-gateway[532]: # TX errors: 0
May 04 21:02:10 rak-gateway ttn-gateway[532]: ### SX1302 Status ###
May 04 21:02:10 rak-gateway ttn-gateway[532]: # SX1302 counter (INST): 120909587
May 04 21:02:10 rak-gateway ttn-gateway[532]: # SX1302 counter (PPS): 120282172
May 04 21:02:10 rak-gateway ttn-gateway[532]: # BEACON queued: 0
May 04 21:02:10 rak-gateway ttn-gateway[532]: # BEACON sent so far: 0
May 04 21:02:10 rak-gateway ttn-gateway[532]: # BEACON rejected: 0
May 04 21:02:10 rak-gateway ttn-gateway[532]: ### [JIT] ###
May 04 21:02:10 rak-gateway ttn-gateway[532]: src/jitqueue.c:440:jit_print_queue(): INFO: [jit] queue is empty
May 04 21:02:10 rak-gateway ttn-gateway[532]: #--------
May 04 21:02:10 rak-gateway ttn-gateway[532]: ### [GPS] ###
May 04 21:02:10 rak-gateway ttn-gateway[532]: # Valid time reference (age: 0 sec)
May 04 21:02:10 rak-gateway ttn-gateway[532]: # GPS coordinates: latitude XX.XXXXX, longitude XX.XXXXX, altitude 52 m
May 04 21:02:10 rak-gateway ttn-gateway[532]: ##### END #####
May 04 21:02:10 rak-gateway ttn-gateway[532]: JSON up: {"stat":{"time":"2023-05-04 20:00:40 GMT","lati":XX.XXXXX,"long":XX.XXXXX,"alti":52,"rxnb":0,"rxok":0,"rxfw":0,"ackr":100.0,"dwnb":0,"txnb":0,"temp":0.0}}
May 04 21:02:10 rak-gateway ttn-gateway[532]: INFO: [up] PUSH_ACK received in 49 ms
May 04 21:02:10 rak-gateway ttn-gateway[532]: INFO: [down] PULL_ACK received in 49 ms
May 04 21:02:10 rak-gateway ttn-gateway[532]: INFO: [down] PULL_ACK received in 45 ms
May 04 21:02:10 rak-gateway ttn-gateway[532]: INFO: [down] PULL_ACK received in 41 ms
May 04 21:02:10 rak-gateway ttn-gateway[532]: ##### 2023-05-04 20:01:10 GMT #####
May 04 21:02:10 rak-gateway ttn-gateway[532]: ### [UPSTREAM] ###
May 04 21:02:10 rak-gateway ttn-gateway[532]: # RF packets received by concentrator: 0
May 04 21:02:10 rak-gateway ttn-gateway[532]: # CRC_OK: 0.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
May 04 21:02:10 rak-gateway ttn-gateway[532]: # RF packets forwarded: 0 (0 bytes)
May 04 21:02:10 rak-gateway ttn-gateway[532]: # PUSH_DATA datagrams sent: 1 (166 bytes)
May 04 21:02:10 rak-gateway ttn-gateway[532]: # SX1302 counter (INST): 150911577
May 04 21:02:10 rak-gateway ttn-gateway[532]: # SX1302 counter (PPS): 150282177
May 04 21:02:10 rak-gateway ttn-gateway[532]: JSON up: {"stat":{"time":"2023-05-04 20:01:10 GMT","lati":XX.XXXXX,"long":XX.XXXXX,"alti":52,"rxnb":0,"rxok":0,"rxfw":0,"ackr":100.0,"dwnb":0,"txnb":0,"temp":0.0}}
May 04 21:02:10 rak-gateway ttn-gateway[532]: INFO: [up] PUSH_ACK received in 63 ms
May 04 21:02:10 rak-gateway ttn-gateway[532]: INFO: [down] PULL_ACK received in 52 ms
May 04 21:02:10 rak-gateway ttn-gateway[532]: INFO: [down] PULL_ACK received in 46 ms
May 04 21:02:10 rak-gateway ttn-gateway[532]: INFO: [down] PULL_ACK received in 69 ms
May 04 21:02:10 rak-gateway ttn-gateway[532]: ##### 2023-05-04 20:01:40 GMT #####
May 04 21:02:10 rak-gateway ttn-gateway[532]: # SX1302 counter (INST): 180912895
May 04 21:02:10 rak-gateway ttn-gateway[532]: # SX1302 counter (PPS): 180282182
May 04 21:02:10 rak-gateway ttn-gateway[532]: # GPS coordinates: latitude XX.XXXXX, longitude XX.XXXXX, altitude 53 m
May 04 21:02:10 rak-gateway ttn-gateway[532]: JSON up: {"stat":{"time":"2023-05-04 20:01:40 GMT","lati":XX.XXXXX,"long":XX.XXXXX,"alti":53,"rxnb":0,"rxok":0,"rxfw":0,"ackr":100.0,"dwnb":0,"txnb":0,"temp":0.0}}
May 04 21:02:10 rak-gateway ttn-gateway[532]: INFO: [up] PUSH_ACK received in 75 ms
May 04 21:02:10 rak-gateway ttn-gateway[532]: INFO: [down] PULL_ACK received in 44 ms
May 04 21:02:10 rak-gateway ttn-gateway[532]: INFO: [down] PULL_ACK received in 47 ms
May 04 21:02:10 rak-gateway ttn-gateway[532]: INFO: [down] PULL_ACK received in 51 ms
May 04 21:02:10 rak-gateway ttn-gateway[532]: ##### 2023-05-04 20:02:10 GMT #####
May 04 21:02:10 rak-gateway ttn-gateway[532]: # SX1302 counter (INST): 210913896
May 04 21:02:10 rak-gateway ttn-gateway[532]: # SX1302 counter (PPS): 210282187
May 04 21:04:10 rak-gateway ttn-gateway[532]: src/jitqueue.c:440:jit_print_queue(): INFO: [jit] queue is empty
May 04 21:04:10 rak-gateway ttn-gateway[532]: ### [GPS] ###
May 04 21:04:10 rak-gateway ttn-gateway[532]: # Valid time reference (age: 0 sec)
May 04 21:04:10 rak-gateway ttn-gateway[532]: # GPS coordinates: latitude XX.XXXXX, longitude XX.XXXXX, altitude 54 m
May 04 21:04:10 rak-gateway ttn-gateway[532]: ##### END #####
May 04 21:04:10 rak-gateway ttn-gateway[532]: JSON up: {"stat":{"time":"2023-05-04 20:02:10 GMT","lati":XX.XXXXX,"long":XX.XXXXX,"alti":54,"rxnb":0,"rxok":0,"rxfw":0,"ackr":100.0,"dwnb":0,"txnb":0,"temp":0.0}}
May 04 21:04:10 rak-gateway ttn-gateway[532]: INFO: [up] PUSH_ACK received in 49 ms
May 04 21:04:10 rak-gateway ttn-gateway[532]: INFO: [down] PULL_ACK received in 41 ms
May 04 21:04:10 rak-gateway ttn-gateway[532]: INFO: [down] PULL_ACK received in 53 ms
May 04 21:04:10 rak-gateway ttn-gateway[532]: ##### 2023-05-04 20:02:40 GMT #####
May 04 21:04:10 rak-gateway ttn-gateway[532]: ### [UPSTREAM] ###
May 04 21:04:10 rak-gateway ttn-gateway[532]: # RF packets received by concentrator: 0
May 04 21:04:10 rak-gateway ttn-gateway[532]: # CRC_OK: 0.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
May 04 21:04:10 rak-gateway ttn-gateway[532]: # RF packets forwarded: 0 (0 bytes)
May 04 21:04:10 rak-gateway ttn-gateway[532]: # PUSH_DATA datagrams sent: 1 (166 bytes)
May 04 21:04:10 rak-gateway ttn-gateway[532]: # PUSH_DATA acknowledged: 100.00%
May 04 21:04:10 rak-gateway ttn-gateway[532]: ### [DOWNSTREAM] ###
May 04 21:04:10 rak-gateway ttn-gateway[532]: # PULL_DATA sent: 3 (100.00% acknowledged)
May 04 21:04:10 rak-gateway ttn-gateway[532]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
May 04 21:04:10 rak-gateway ttn-gateway[532]: # RF packets sent to concentrator: 0 (0 bytes)
May 04 21:04:10 rak-gateway ttn-gateway[532]: # TX errors: 0
May 04 21:04:10 rak-gateway ttn-gateway[532]: ### SX1302 Status ###
May 04 21:04:10 rak-gateway ttn-gateway[532]: # SX1302 counter (INST): 240914904
May 04 21:04:10 rak-gateway ttn-gateway[532]: # SX1302 counter (PPS): 240282192
May 04 21:04:10 rak-gateway ttn-gateway[532]: # BEACON queued: 0
May 04 21:04:10 rak-gateway ttn-gateway[532]: # BEACON sent so far: 0
May 04 21:04:10 rak-gateway ttn-gateway[532]: # BEACON rejected: 0
May 04 21:04:10 rak-gateway ttn-gateway[532]: ### [JIT] ###
May 04 21:04:10 rak-gateway ttn-gateway[532]: #--------
May 04 21:04:10 rak-gateway ttn-gateway[532]: # GPS coordinates: latitude XX.XXXXX, longitude XX.XXXXX, altitude 56 m
Any thoughts on what I can check next would be appreciated.
Many thanks
