RAK2470- Humidty payload
Hello Rak users,
I recently got a RAK2470, a great device for me.
But I was wondering if the payload of a Humidity sensor is correct?
For a Humidty the payload should be “02 68 01AB”, and not “02 70 01AB”
Or did I misunderstand?
Hi @Marchel ,
Regarding the payload format, the WisNode Bridge RAK2470 has its own protocol and doesn’t follow the standardized payload decoder based on cayennelpp., the payload format for IO.box on humidity is high accuracy type. So it uses 70 instead of 68.
If you generate the payload decoder on IO.box, you can see that it points to 112 which is equivalent to 70.
Thanks for the quick explanation @carlrowan ,
I couldn’t find that in the manual.
