RAK2470 : IMPORT limitation on number of records?
Hello RAK user,
I wanted to import 44 sensors (records) in the RAK2470; but no more than 41 were imported. Manually in the configuration screen I could enter the same sensor. Is there a maximum number of sensors to import? No error or other message appears. Nor how many records were successfully imported or not.
Hi @Marchel ,
Can you please provide me the spreadsheet file so I can try it on our end? You can send to my email [email protected] or via inbox here in forum.
Hello Carl,
Hello Carl,
The document is attached hereto, it does not contain any special (personal) data.
Then others can possibly also learn from my mistakes if I have made them.
The cause may also be that fictitious sensors were used as an import test and something went wrong because of that.
BEEP-MODBUS-44.xlsx (10.9 KB)
Hi @Marchel ,
Your BEEP usecase sounds familiar. I have email/ticket support relate to this.
I checked your file and created some modifications.
Please check here the changes I did
BEEP-MODBUS-44-modified.xlsx (10.9 KB)
This should import the 44 parameters successfully.
Hello @carlrowan
I’ve seen it, field “Name” (or Remark in Excelsheet) has been given a unique property.
Also solved again!
thanks again for your sharp eye
Marchel
