I’m looking for any documentation on using SDI-12 with the Sensor Probe IO. I have all the hardware… just not sure how to setup the SDI-12 using wistoolbox.
Welcome back to forum @everhamme ,
We are working on some SDI-12 sensors (focused on Agricultural applications). However, for custom SDI-12 commands in WisToolBox, it is not supported yet.
We are finalizing SDI-12 library for RUI3. When this is released, you can create a custom firmware using RUI3 on either RAK3172, RAK4630 or RAK11720 then use WisToolBox.
Is the SDI-12 implemented yet or is there a way for me to write custom firmware?
I have a SDI-12 sensor that I would like to use with the ProbeIO I have but I cannot find any documentation.
Thanks,
Welcome to RAK forum @Frankie ,
We have SDI-12 sensors working on Sensorhub. However, for custom or other SDI-12 sensor/devices, we can help you integrate it by developing the driver code.
The ProbeIO has its own small internal MCU that manages the SDI-12 interface then converts it to One-wire serial. If you have to develop your own firmware, that should be possible.
But if you need our help for a specific SDI-12 device, you can send the details at [email protected]
Carl,
That is fantastic, thankyou.
Frank
Carl,
Just out of interest and for the benefit of others are there any public repositories/ examples/ available? And if so where could they be found?
Thanks,
Frank
Hi @Frankie ,
Sensor Hub is not open source. It is not in the current roadmap to make it open source.
Might not be a good news but I cannot direct you to any public repo related to it.
