RAK3172 AES128 KEY / STATE remembered
Does the RAK3172 (RUI4.0.6) remember the AES128 encryption key and encryption state (enable/disable) when the power is cycled?
Thank you.
Frank.
Did not test on V4.0.6, but in V4.2.0 it does keep the key and the status
Thanks Bernd,
I’m can’t see RUI 4.2.0 in the download center.
Is this version officially released?
What is the difference between 4.0.6 and 4.2.0?
Thank You.
Frank.
Hi Bernd,
As you can see the Download Centre doesn’t tell you the version release…
It just says “latest”.
It would better if it actually spelled out the release version.
RUI3 Release Notes
Changelog (Same as single file)
xxx_latest_xxx file is the latest released firmware for the different devices.
For RAK3172 that is V4.2.0
RAK3172 (without TCXO)
  • RAK3172-E_latest.bin
  • RAK3172-E_latest_final.hex
    RAK3172-T (with TCXO)
  • RAK3172-T_latest.bin
  • RAK3172-T_latest_final.hex
    RAK3172-SiP
  • RAK3272-SiP_latest.bin
  • RAK3272-SiP_latest_final.hex
    RAK3172LP-SiP
  • RAK3272LP-SiP_latest.bin
  • RAK3272LP-SiP_latest_final.hex
If using RAK DFU tool or WisToolBox you can use ****.bin file
If using JLink or STM32CubeProgrammer you can use ***.hex file
