I’m using RAK3172 for my project (in C for STM32WLE5) and I need to check when the module can send a packet. I use IRQ_PREAMBLE_DETECTED in the interrupt to check for free airtime. Data size 10–128 bytes.
Is the correct way to check if data can be sent?
I also have a queue in my device where all the commands to be sent are added with a pause between them - 500 ms.
How to check when the device will be able to send the next message on the air?
@carlrowan
hello,
yes, I have read this forum. But I didn’t find any normal example with CAD. For now I get always IRQ_CAD_DETECTED after enabling it. I think it is wrong because this interrupt might be set when the signal is detected.
Hi @carlrowan
Can you explain how I can tune settings for CAD?
for now, I sometimes have false IRQ from CAD. I use these settings with spreadfactor 10:
symbol = LORA_CAD_04_SYMBOL
Detect Peak = 24
Detect Min = 10
Cad Exit Mode = LORA_CAD_RX
Cad Timeout = 10000
how it work? what does it means “Cad timeout”? Is it timeout for all my packages or only for finding preamble?
I tried to change timeout - but with timeout <10000 - the node doesn’t receive anything, but I have CAD_DETECT.
If I set timeout >10000 - the node receives correctly, but I have a timeout for sending - from CAD_DETECT to CAD_CLEAR
In the datasheet from STM for stm32wle - these parameters need to be tuned, but how can I tune it correctly?
