RAK3172 LoRa P2P not sending
Hello I’m having some troubles with the RAK3172 module, first time I upload the code it’s working and when I reupload the same code it’s not working. Here it’s my custom PCB schematic :
And the code I’ve tryed arduino and also the example from RAK based on stm32.
And here it’s my code that is working on the first time programming only:
Welcome to the forum @Athereos
What does “not working” mean? It does not start at all or it starts, but throws errors or hangs?
How do you upload the code? I see UART2 is not connected, so it is either STM32CubeProgrammer or Jlink?
Code generated from the compilation is not including the RAK bootloader, so you must not do a Chip Erase before uploading a new firmware. Otherwise you loose the RAK bootloader and the device will not start the application.
Hello Bernd, I use STM32CubeProgrammer to program it, and the code works and when I enter on debug mode it’s doing all the processes but when I measure the current it does not increase at the sending process, but the first time that it’s working the current increased up to 100mA.
Also I have a reciever and didn’t recieve nothing from this RAK the second time I programmed it.
Sorry, I can’t help with code from STM32CubeIDE.
What code based on RUI3 did you try?
Yes I just tryed this and didn’t work I get no transmission from RAK
#include <Arduino.h>
uint32_t TempSensorSN = 0;
float CurrentTemp = 0;
uint8_t array[11];
uint16_t SleepTime = 10;
uint32_t STS31_GetSN() {
return 0x12345678; // número de serie fake
float STS31_read_temp() {
return 25.37; // valor ficticio
// ---------------- Setup ----------------
void setup() {
delay(2000);
// Cambiar a modo P2P
if(api.lora.nwm.get() != 0)
Serial.printf(“Set Node device work mode %s\r\n”,
api.lora.nwm.set() ? “Success” : “Fail”);
api.system.reboot();
api.lora.pfreq.set(868000000); // Frecuencia
api.lora.psf.set(7); // Spreading Factor
api.lora.pbw.set(125); // Bandwidth (kHz)
api.lora.pcr.set(1); // Coding Rate 4/5
api.lora.ppl.set(8); // Preamble length
api.lora.ptp.set(22); // Potencia de TX (dBm)
// ---------------- Loop ----------------
void loop() {
uint16_t Battery = 3700;
int8_t TempInt;
uint8_t TempDec;
Battery = analogRead(PA1);
TempSensorSN = STS31_GetSN();
for (int i = sizeof(uint32_t) - 1; i >= 0; --i) {
array[i] = (uint8_t)(TempSensorSN >> ((sizeof(uint32_t) - 1 - i) * 8));
array[6] = (uint8_t)(Battery >> 8);
array[7] = (uint8_t)(Battery & 0xFF);
array[8] = 0x4B; // ID
array[9] = 0xAC; // ID
CurrentTemp = STS31_read_temp();
TempInt = (int16_t)CurrentTemp;
TempDec = ((int)(CurrentTemp * 100) % 100);
array[4] = (uint8_t)TempInt;
array[5] = (uint8_t)TempDec;
// ---- TX ----
Serial.println(“Enviando paquete LoRa P2P…”);
api.lora.psend(sizeof(array), array);
delay(1000);
Thanks.
You could have a timing problem.
Your P2P settings and the payload length results in a “time on air” of nearly 1 second.
You repeat the loop every 1 second.
Does anything change if you switch to 2 seconds or longer?
What does api.lora.psend(sizeof(array), array);, does it return true or false?
How is your receiver setup? Is it RUI3 as well?
I finally managed to fix it on stm32, it was the config of the “clock” just like this
And now it’s working :
But now I want to put the micro on sleep mode but i can’t get a decent consumption, I get 352 uA and it has to be about 2uA.
There’s an specific command to put in on sleep appart from this?
 		HAL_Delay(Radio.GetWakeupTime() +1000);
 		uint8_t array[11];
 		array[0] = 0x11;
 		array[1] = 0x12;
 		array[2] = 0x13;
 		array[3] = 0x14;
 		array[4] = 0x05;
 		array[5] = 0x06;
 		array[6] = 0x01; //ID
 		array[7] = 0x12; //ID
 		array[8] = 0x4b; //ID
 		array[9] = 0xAC; //ID
 	Radio.Send((uint8_t *)array, sizeof(array));
 	UTIL_LPM_EnterLowPower();
