RAK3172 P2P Frequency Change Without Flash Write
I would like to change the frequency frequently in RAK3172 LoRa P2P mode (RUI3). I plan to control the module from an external MCU using AT commands.
How can I add a custom AT command that changes the operating frequency without saving the new value to non-volatile memory?
I would like to avoid writing to flash memory every time the frequency changes, since flash has a limited number of write cycles. My goal is to update the frequency dynamically during operation without affecting the lifetime of the non-volatile storage.
Thank you for any suggestions.
Welcome to the forum @Darek
It is at the moment not possible to change the P2P frequency with AT commands without triggering a flash write.
It would require a custom RUI3 firmware to do this.
Thank you for your reply.
I tried to add a custom AT command that would change the radio frequency without saving the new value to flash memory. I used the function api.lora.pfreq.set() , but it appears that this function also writes the setting to flash.
Which function should I use if I want to change the operating frequency only at runtime, without storing the new value in flash?
Thank you for your help.
There is no such function available on API level. You would have to access directly the LoRa drivers function to set the frequency.
