I am interfering with the acknowledgement of uplink frames at a certain frequency, causing the terminal to not receive the correct acknowledgement frame, when the terminal should choose a time to retransmit.
But my code will make the terminal only retransmit uplink frames with the same load in the uplink_routine function, but for the gateway, these frames are just the same load with different frame numbers. Is this a retransmission?
If not, how should my code be modified to add so that my terminal can automatically retransmit outside of uplink_routine.
Also, what is the maximum number of retransmissions the rak3172 can do? How do I set the value of rety?
I have the following code:
// This example shows LoRaWan protocol joining the network in OTAA mode, class A, region CN470.
// Device will send uplink every 30 seconds.
#define OTAA_PERIOD (30000)
LoRaWAN band setting:
RAK_REGION_EU433
RAK_REGION_CN470
RAK_REGION_RU864
RAK_REGION_IN865
RAK_REGION_EU868
RAK_REGION_US915
RAK_REGION_AU915
RAK_REGION_KR920
RAK_REGION_AS923
#define OTAA_BAND (RAK_REGION_CN470)
#define OTAA_DEVEUI {---}
#define OTAA_APPEUI {---}
#define OTAA_APPKEY {---}
/** Packet buffer for sending */
uint8_t collected_data[64] = { 0 };
uint16_t packet_id = 0; // id number from 0
void recvCallback(SERVICE_LORA_RECEIVE_T * data)
if (data->BufferSize > 0) {
Serial.print("\r\n");
* enum type for LoRa Event
RAK_LORAMAC_STATUS_OK = 0,
RAK_LORAMAC_STATUS_ERROR,
RAK_LORAMAC_STATUS_TX_TIMEOUT,
RAK_LORAMAC_STATUS_RX1_TIMEOUT,
RAK_LORAMAC_STATUS_RX2_TIMEOUT,
RAK_LORAMAC_STATUS_RX1_ERROR,
RAK_LORAMAC_STATUS_RX2_ERROR,
RAK_LORAMAC_STATUS_JOIN_FAIL,
RAK_LORAMAC_STATUS_DOWNLINK_REPEATED,
RAK_LORAMAC_STATUS_TX_DR_PAYLOAD_SIZE_ERROR,
RAK_LORAMAC_STATUS_DOWNLINK_TOO_MANY_FRAMES_LOSS,
RAK_LORAMAC_STATUS_ADDRESS_FAIL,
RAK_LORAMAC_STATUS_MIC_FAIL,
RAK_LORAMAC_STATUS_MULTICAST_FAIL,
RAK_LORAMAC_STATUS_BEACON_LOCKED,
RAK_LORAMAC_STATUS_BEACON_LOST,
RAK_LORAMAC_STATUS_BEACON_NOT_FOUND,
if (status == RAK_LORAMAC_STATUS_OK) {
Serial.println("Successfully sent");
} else {
Serial.println("Sending failed");
void setup()
Serial.begin(115200, RAK_AT_MODE);
delay(2000);
Serial.println("RAKwireless LoRaWan OTAA Example");
if(api.lorawan.nwm.get() != 1)
Serial.printf("Set Node device work mode %s\r\n",
api.lorawan.nwm.set() ? "Success" : "Fail");
api.system.reboot();
// OTAA Device EUI MSB first
uint8_t node_device_eui[8] = OTAA_DEVEUI;
// OTAA Application EUI MSB first
uint8_t node_app_eui[8] = OTAA_APPEUI;
// OTAA Application Key MSB first
uint8_t node_app_key[16] = OTAA_APPKEY;
if (!api.lorawan.appeui.set(node_app_eui, 8)) {
Serial.printf("LoRaWan OTAA - set application EUI is incorrect! \r\n");
return;
if (!api.lorawan.appkey.set(node_app_key, 16)) {
Serial.printf("LoRaWan OTAA - set application key is incorrect! \r\n");
return;
if (!api.lorawan.deui.set(node_device_eui, 8)) {
Serial.printf("LoRaWan OTAA - set device EUI is incorrect! \r\n");
return;
if (!api.lorawan.band.set(OTAA_BAND)) {
Serial.printf("LoRaWan OTAA - set band is incorrect! \r\n");
return;
if (!api.lorawan.deviceClass.set(RAK_LORA_CLASS_A)) {
Serial.printf("LoRaWan OTAA - set device class is incorrect! \r\n");
return;
if (!api.lorawan.njm.set(RAK_LORA_OTAA)) // Set the network join mode to OTAA
Serial.printf("LoRaWan OTAA - set network join mode is incorrect! \r\n");
return;
if (!api.lorawan.join()) // Join to Gateway
Serial.printf("LoRaWan OTAA - join fail! \r\n");
return;
/** Wait for Join success */
api.lorawan.join();
delay(10000);
if (!api.lorawan.adr.set(false)) {
Serial.printf("LoRaWan OTAA - set adaptive data rate is incorrect! \r\n");
return;
if (!api.lorawan.rety.set(4)) {
Serial.printf("LoRaWan OTAA - set retry times is incorrect! \r\n");
return;
if (!api.lorawan.cfm.set(1)) {
Serial.printf("LoRaWan OTAA - set confirm mode is incorrect! \r\n");
return;
if (!api.lorawan.dr.set(0)) { // dr=5ďźsf=7,bw=125kHz dr=0,sf=12,bw=125
Serial.printf("LoRaWan OTAA - set data rate is incorrect! \r\n");
return;
/** Check LoRaWan Status*/
Serial.printf("Duty cycle is %s\r\n", api.lorawan.dcs.get()? "ON" : "OFF"); // Check Duty Cycle status
Serial.printf("Packet is %s\r\n", api.lorawan.cfm.get()? "CONFIRMED" : "UNCONFIRMED"); // Check Confirm status
uint8_t assigned_dev_addr[4] = { 0 };
Serial.printf("Device Address is %02X%02X%02X%02X\r\n", assigned_dev_addr[0], assigned_dev_addr[1], assigned_dev_addr[2], assigned_dev_addr[3]); // Check Device Address
Serial.printf("Uplink period is %ums\r\n", OTAA_PERIOD);
Serial.println("");
void uplink_routine()
/** Payload of Uplink */
uint8_t data_len = 0;
collected_data[data_len++] = (uint8_t) 't';
collected_data[data_len++] = (uint8_t) 'e';
collected_data[data_len++] = (uint8_t) 's';
// 桝ĺ ĺŻä¸çźĺˇ
collected_data[data_len++] = (uint8_t) ('0' + (packet_id % 10)); // Retain only single-digit numbers
Serial.println("Data Packet:");
for (int i = 0; i < data_len; i++) {
Serial.printf("0x%02X ", collected_data[i]);
Serial.println("");
/** Send the data package */
if (api.lorawan.send(data_len, (uint8_t *) & collected_data, 2, true, 1)) {
Serial.println("Sending is requested");
delay(5000);
Serial.printf("Send confirm %s\r\n", api.lorawan.cfs.get() ? "Success" : "Fail");
if (api.lorawan.cfs.get()) {
packet_id++; // Incremental numbering upon receipt of confirmation
} else {
void loop()
static uint64_t last = 0;
static uint64_t elapsed;
if ((elapsed = millis() - last) > OTAA_PERIOD) {
last = millis();
uplink_routine();
// //Serial.printf("Try sleep %ums..", OTAA_PERIOD);
// api.system.sleep.all(OTAA_PERIOD);
// //Serial.println("Wakeup..");
