Hi.
- I cannot switch the band to AS923-1-JP as described in the RUI3 manual.
at+band=?
AT+BAND=8
OK
at+band=8-1-JP
AT_PARAM_ERROR
Listen-Before-Talk may not be working.
This is a required feature of AS923-1-JP, so it’s probably a bug that it doesn’t work now. -
The maximum payload size that can be sent is incorrect.
I bet you forgot to subtract the MAC header size (at least 8 bytes).
For example in DR2 it should be possible up to 11 bytes.
However, 19 bytes have been sent.
+EVT:JOINED
at+dr=?
AT+DR=2
OK
at+send=2:0123456789abcdef01234567890acdef01234567
AT_PARAM_ERROR
OK
+EVT:SEND_CONFIRMED_OK
This issue has appeared with the RAK811 and appears to have been resolved in the past.
These problems are serious because there is a high risk of violation of the law if it is used as it is in Japan.
