Good Day for everyone,
can someone help with connectivity issue.
According doc: RAK3172 Module Quick Start Guide | RAKwireless Documentation Center
Serial configuration will be:
- Baud Rate: 9600 baud
- Data Bits: 8 bits
- Stop Bits: 1 stop bit
- Parity: NONE
From the “RAK Serial Port Tool” where able to select only PortName + Baud Rate everything working properly but… If I try to use some different tools like Putty or custom code based on Posix Termios - have errors or black window.
Can someone share code how to initialize Serial for device in any programming language? Linux and Termios - it’s better.
Or share these information from “RAK Serial Port Tool” sources (As I see - sources of this tool not available).
Thanks.
