With RUI_4.0.5_RAK3172-E and P2P mode, Is it posible to wakeup by radio? How to do?
If you setup the device correct, it will automatically wake-up on a received data packet.
If using AT command interface in LoRa P2P mode:
AT+PRECV=xxxxx
xxxxx larger than 0 will set the LoRa transceiver into RX mode and if a valid packet arrived, it will give feedback over UART2 with
+EVT:RXP2P:-112:1:1234
More details about AT+PRECV ==> AT Command Manual | RAKwireless Documentation Center
When using custom firmware based on RUI3 API:
Define callback functions:
* @brief LoRa P2P callback if a packet was received
* @param data
void recv_cb(rui_lora_p2p_recv_t data)
Serial.printf("P2P RX, RSSI %d, SNR %d\r\n", data.Rssi, data.Snr);
for (int i = 0; i < data.BufferSize; i++)
Serial.printf("%02X", data.Buffer[i]);
Serial.print("\r\n");
* @brief LoRa P2P callback if a packet was sent
void send_cb(void)
Serial.println("P2P TX finished");
Initialize the callbacks and set P2P RX mode:
api.lora.registerPRecvCallback(recv_cb);
api.lora.registerPSendCallback(send_cb);
// Enable RX mode (always with TX allowed)
api.lora.precv(65533);
Keep in mind that in RX mode, the LoRa transceiver is not in sleep mode. You have to expect a current consumption of several mA.
However, the MCU itself can go into sleep mode.
I just realized that in RX mode, the LoRa transceiver is not in sleep mode, Thank you.
