Hi, where can i download the bootloader/AT firmware 4.1.0 to the RAK3272 ?
And is there some API command to see if the RAK3272 is answering to an AT command ? Because after 60000 packages sent (interval 10 seconds), something freeze…
I want to verify if the Arduino app on RAK3272 still is receiveing a OK for the API send commands…
It is not possible from the API to do that directly.
What you can do is to add a custom AT command that informs your application when it has received an AT command.
You could define a simple custom AT command that sets a flag for your code. Your host MCU would have to send this custom AT command frequently and your code checks if the AT command was received in the expected time.
Custom AT commands are handled by the same code that is handling standard AT commands.
