RAK4200 and RAK811 Breakout Board
Well I successfully flashed the RAK811 with new firmware RAK811 Version:3.0.0.14.H but I cant seem to get it to do an OTAA join with TTN?
I am using AU915 and my gateway is a Dragino LPS8, I tested it with ABP and it works fine as it should but it does not do a OTAA join no matter what settings I try?
I followed the instructions at:
Any ideas?
Ensure you’ve set the class & join_mode, perhaps use the RAK docs, if it doesn’t work, can you post the output from the serial tool.
https://docs.rakwireless.com/Product-Categories/WisDuo/RAK811-Breakout-Board/Quickstart/#otaa-mode
Dear James,
OMG!This is a serious mistake!
Thank you for identifying the problem, which is great!
You must send the at command to add it to the network!
Best regards!
Hi Guys,
I did use all those commands to get it to try to join OTAA
at+set_config=lora:join_mode:0
at+set_config=lora:class:0
at+set_config=lora:region:AU915
at+set_config=lora:dev_eui:my key goes here from TTN
at+set_config=lora:app_eui:my key goes here from TTN
at+set_config=lora:app_key:my key goes here from TTN
at+join
error:99
As mentioned for ABP works like a charm!
Dear James,
You need check channel by AT command:
> at+get_config=lora:channel
Make sure gateway and node is the same!
