Issue: Setting Up to use SF12 LoRa P2P
Setup: One node as Transmitter and One node as Receiver (UART control with ESP32)
Server: P2P Method
Details: I am trying to transmit data using SF12 125kHz 4/5 coding rate at 433MHz.
It does response ok once transmit but for receiver side it wont datalog / decode the transmit information such as RSSI, S/N, data lenght and data. What whould be the configuration needed to enable SF12?
