Hi, i’m a newbie. I have a gateway( RAK2287 + RPi 4) and a RAK4200 Evaluation board (868Mhz). I want to setup a demo with built-in Lora ChirpStack Server , but when i send ‘at+join’ command, it always responds " error 99". Here is my settup :
Setup:
Do you see join uplinks in the gateway traffic? when you send at+join command? How many times did you try to send at+join request? Is it always ERROR: 99 all the time?
If you see uplink join traffic in the gateway but failing, can you try to disable channels not used for join uplinks frequencies by sending this commands:
the first time, i set ApEUI is full of zero and the respond is ’ error 82 ’ so I change ApEUI is the same DevEUI but I get error 99 for 10 or … I don’t know… several times
That PCB antenna should be ok. Do you see the label EU868?
The problem I think is still on the gateway side. The 'Last seen at` status of your gateway is never on the screenshot you sent. Even if you don’t have a device that is transmitting, that should be updating on its own. Are you sure your Gateway ID is correct when you added your gateway?
I copy the ID from " sudo gateway-version" so I think it’s correct. Do I need change GW ID in global_config file? I did not do it because I think local_config overwrite on it?
