Issue:I have both the RAK4200 and RAK4270 breakout boards. Both are set with the same parameters. The RAK4270 joins our gateway, the RAK4200 returns error 99.
Setup: RAK4200(H) breakout boards (multiple fail to join gateway)
RAK4270(H) all join the gateway. More setup in the details.
Server:
Details:
Here are the version, status, and channel settings for the RAK4200(H):
MSG> lora get device status
at+get_config=device:status
OK
Board Core:RAK4200
MCU:STM32L071KB
LoRa chip:SX1276
MSG> lora get version
at+version
OK
V3.2.0.14
MSG> lora get lora status
at+get_config=lora:status
OK
Work Mode: LoRaWAN
Region: US915
MulticastEnable: false
DutycycleEnable: false
Send_repeat_cnt: 0
Join_mode: OTAA
DevEui: 60C5A8FFFE78F370
AppEui: AC1F09FFF9154270
AppKey: 3266B57DD6A808106999C5C90A8D8776
Class: A
Joined Network:false
IsConfirm: confirm
AdrEnable: false
EnableRepeaterSupport: false
RX2_CHANNEL_FREQUENCY: 923300000, RX2_CHANNEL_DR:8
RX_WINDOW_DURATION: 3000ms
RECEIVE_DELAY_1: 1000ms
RECEIVE_DELAY_2: 2000ms
JOIN_ACCEPT_DELAY_1: 5000ms
JOIN_ACCEPT_DELAY_2: 6000ms
Current Datarate: 3
Primeval Datarate: 3
ChannelsTxPower: 0
UpLinkCounter: 0
DownLinkCounter: 0
MSG> lora get lora channel
at+get_config=lora:channel
OK
0,off,902300000,0,3; 1,off,902500000,0,3; 2,off,902700000,0,3; 3,off,902900000,0,3; 4,off,903100000,0,3; 5,off,90330000
0,0,3; 6,off,903500000,0,3; 7,off,903700000,0,3; * 8,on,903900000,0,3; * 9,on,904100000,0,3; *10,on,904300000,0,3; *11,on,
904500000,0,3; *12,on,904700000,0,3; *13,on,904900000,0,3; *14,on,905100000,0,3; *15,on,905300000,0,3; 16,off,905500000,0,3;
17,off,905700000,0,3; 18,off,905900000,0,3; 19,off,906100000,0,3; 20,off,906300000,0,3; 21,off,906500000,0,3; 22,off,906700
000,0,3; 23,off,906900000,0,3; 24,off,907100000,0,3; 25,off,907300000,0,3; 26,off,907500000,0,3; 27,off,907700000,0,3; 28,of
f,907900000,0,3; 29,off,908100000,0,3; 30,off,908300000,0,3; 31,off,908500000,0,3; 32,off,908700000,0,3; 33,off,908900000,0,
3; 34,off,909100000,0,3; 35,off,909300000,0,3; 36,off,909500000,0,3; 37,off,909700000,0,3; 38,off,909900000,0,3; 39,off,9101
00000,0,3; 40,off,910300000,0,3; 41,off,910500000,0,3; 42,off,910700000,0,3; 43,off,910900000,0,3; 44,off,911100000,0,3; 45,
off,911300000,0,3; 46,off,911500000,0,3; 47,off,911700000,0,3; 48,off,911900000,0,3; 49,off,912100000,0,3; 50,off,912300000,
0,3; 51,off,912500000,0,3; 52,off,912700000,0,3; 53,off,912900000,0,3; 54,off,913100000,0,3; 55,off,913300000,0,3; 56,off,91
3500000,0,3; 57,off,913700000,0,3; 58,off,913900000,0,3; 59,off,914100000,0,3; 60,off,914300000,0,3; 61,off,914500000,0,3; 6
2,off,914700000,0,3; 63,off,914900000,0,3; 64,off,903000000,4,4; 65,off,904600000,4,4; 66,off,906200000,4,4; 67,off,90780000
0,4,4; 68,off,909400000,4,4; 69,off,911000000,4,4; 70,off,912600000,4,4; 71,off,914200000,4,4
Here are the version, status, and channel settings for the RAK4270(H):
OK
Board Core:RAK4270
MCU:STM32L071KB
LoRa chip:SX1262
at+version
OK
V3.3.0.14
OK
Work Mode: LoRaWAN
Region: US915
Send_repeat_cnt: 0
Join_mode: OTAA
Class: A
Joined Network:true
IsConfirm: confirm
AdrEnable: false
Current Datarate: 3
ChannelsTxPower: 0
UpLinkCounter: 0
DownLinkCounter: 0
OK
All of our RAK4270 breakout boards join our test gateway successfully. None of the RAK4200 breakout boards join our test gateway - all return Error 99. As you can see above, I have configured a RAK4200(H) with the same exact settings as the RAK4270(H). We have some RAK4200(H) USB boards from RAK, these do join the gateway. It is only RAK4200(H) breakout modules that our client has recently purchased from RAK that are failing. Both types of breakout boards have been tested plugged into the same hardware platform with identical firmware communicating with the RAK modules.
We would like your help to troubleshoot this issue so that our client’s inventory of RAK4200(H) modules will work in their product. Please let me know what other infomation I might provide.
Thank you,
Tom W.
