Issue: When the RAK4270 receives an ADR command from the server sometimes reports ERROR 20
Setup: EU868
Server:
Details:
A payload is sent from the RAK4270 every 15 minutes.
After 20 payloads the RAK4270 receives an ADR command from the server and the RAK4270 generates an ERROR 80
Payload 1
OK Wake Up
*** WAKE UP Confirmed ***
at+send=lora:1:070ddf0100c2022a0604a735000734002c42008943006e4400d41C6913
*** UPLINK COMPLETE - NO DOWNLINK ***
at+set_config=device:sleep:1
OK Sleep
*** SLEEP Confirmed ***
Payload 20 - (ADR Sent by Server)
at+set_config=device:sleep:0
OK Wake Up
at+send=lora:1:070ddf0100c4022b06052b35000734003642008b4300794400cf1C68e7
ERROR: 80
The RAK4270 does not process the ADR correctly !
and generates ERROR 80 after sleep command
What exactly is ERROR 80 and how should it be processed ?
Thank You
