Issue: After programming the deveui and appkey - an Error 82 (The Lora Parameters are invalid) is generated when trying to join Lora network
Setup: Any firmware revision : V3.3.0.15 , V3.3.0.16 and V3.3.0.18
Details: A new RAK4720 will join the LoRa network without any problem in the default OTAA mode
After programming the RAK4270 the Error 82 Occurs. Reflashing the RAK4270 with the same firmware version or a different firmware version does not overcome the error.
Using the command at+set_config=lora:default_parameters also does not overcome the error 82.
Programming Sequence
at+set_config=device:sleep:0
OK Wake Up
at+set_config=lora:dev_eui:6xxxxxxxxxxxxx8
OK
at+set_config=lora:dev_addr:00000000
OK
at+set_config=lora:app_eui:0000000000000000
OK
at+set_config=lora:app_key:566B59703273357638792F423F452848
OK
at+set_config=lora:apps_key:566B59703273357638792F423F452848
OK
at+set_config=lora:nwks_key:566B59703273357638792F423F452848
OK
at+set_config=lora:join_mode:0
OK
at+set_config=lora:confirm:0
OK
at+set_config=lora:adr:1
OK
at+set_config=lora:region:EU868
OK
at+set_config=lora:class:0
OK
at+set_config=lora:dr:5
OK
Restarting Lora
Reading RAK4270
OK Wake Up
at+version
OK V3.3.0.15
at+set_config=device:restart
at+get_config=lora:status
OK Work Mode: LoRaWAN
Region: EU868
MulticastEnable: false
DutycycleEnable: false
Send_repeat_cnt: 0
Join_mode: OTAA
DevEui: 6xxxxxxxxxxxxx8
AppEui: 0000000000000000
AppKey: 566B59703273357638792F423F452848
Class: A
Joined Network:false
IsConfirm: unconfirm
AdrEnable: true
EnableRepeaterSupport: false
RX2_CHANNEL_FREQUENCY: 869525000, RX2_CHANNEL_DR:0
RX_WINDOW_DURATION: 3000ms
RECEIVE_DELAY_1: 1000ms
RECEIVE_DELAY_2: 2000ms
JOIN_ACCEPT_DELAY_1: 5000ms
JOIN_ACCEPT_DELAY_2: 6000ms
Current Datarate: 5
Primeval Datarate: 5
ChannelsTxPower: 0
UpLinkCounter: 0
DownLinkCounter: 0
OK
