Paul, that’s not a firmware update, it’s making what you discovered more obvious in the docs.
You could put some sort of MOSFET switch in the line controlled by the MCU.
Or you could, for this iteration, live with the wasted power - I see that idle mode isn’t documented - I’d guess at 5mA - and you could send a sleep command immediately if the MCU doesn’t need to use the module.
The question regarding firmware was added because beegee mentioned in another post about there being a new firmware and I wanted to ask Carl if he knew of any dates
I asked the FW team about the target release. But for now I don’t have the official words from them yet. Hopefully I get the info tomorrow and I will update you ASAP.
