As I connected to UART1, the effect is the same. I was only able to connect via BLE.
I tried on two different adapters, each of them works on different devices.
I am using your RAK Serial Port Tool software.
I also noticed that until I send any at command via BLE, the current consumption of the board is very small.
Only after sending same command does it increase significantly.
I use an external power supply for power supply.
Setup:
Device firmware: V3.4.0.14
External power supply: 3.3V, 1A
Software: RAK Serial Port Tool
UART adapter: USB-UART FT232
Server:
Details:
Could someone explain to me how to connect the board so that it works over UART?
Thanks,
Dawid
