I was wondering if it is possible to set (and read) the FCntUp value from the AT commands layer? If no, would it be possible to achieve this in any other way, perhaps RUI?
The reason for this is because I want to shut the module completely off during the low power (sleep) periods, and to keep up with the LoRaWAN specification I need to make sure that the current value of FCntUp will be retained even after shutting off the LoRaWAN module.
Thank you for your help.
