RAK4630 + I2C = LoRaWAN Faillure + Microcontroller Stop
Hello Everyone,
We are facing an issue using RAK4630 board and the 1906 environmental sensor based on bme680 from Bosh.
When used alone, the LoRaWAN connection work fine in our private LoRaWAN network. But as soon as we try to implement the code to read temperature from 1906 sensor. Connection fail and the microcontroller stay blocked (no activity anymore).
In order to isolate the problem, we just made a simple code based on the LoRaWAN_OTAA_ABP example. We added a few lines:
//At the beginning
#include <Wire.h>
#define BME680_ADDR 0x76
//in the loop:
void loop()
  Serial.println("Still Alive!");
  read16(0xE9);
  delay(1000);
//And the function:
uint16_t read16(uint8_t reg) {
  Wire.beginTransmission(BME680_ADDR);
  Wire.write(reg);
  Wire.endTransmission();
  Wire.requestFrom(BME680_ADDR, 2);
  uint8_t lo = Wire.read();
  uint8_t hi = Wire.read();
  return (hi << 8) | lo;
Here the complete example:
 * @file LoRaWAN_OTAA_ABP.ino
 * @author rakwireless.com
 * @brief LoRaWan node example with OTAA/ABP registration
 * @version 0.1
 * @date 2020-08-21
 * @copyright Copyright (c) 2020
 * @note RAK4631 GPIO mapping to nRF52840 GPIO ports
   RAK4631    <->  nRF52840
   WB_IO1     <->  P0.17 (GPIO 17)
   WB_IO2     <->  P1.02 (GPIO 34)
   WB_IO3     <->  P0.21 (GPIO 21)
   WB_IO4     <->  P0.04 (GPIO 4)
   WB_IO5     <->  P0.09 (GPIO 9)
   WB_IO6     <->  P0.10 (GPIO 10)
   WB_SW1     <->  P0.01 (GPIO 1)
   WB_A0      <->  P0.04/AIN2 (AnalogIn A2)
   WB_A1      <->  P0.31/AIN7 (AnalogIn A7)
#include <Arduino.h>
#include <SPI.h>
#include <Wire.h>
// RAK4630 supply two LED
#ifndef LED_BUILTIN
#define LED_BUILTIN 35
#endif
#ifndef LED_BUILTIN2
#define LED_BUILTIN2 36
#endif
bool doOTAA = true;   // OTAA is used by default.
#define SCHED_QUEUE_SIZE 60										  /**< Maximum number of events in the scheduler queue. */
#define LORAWAN_DATERATE DR_0									  /*LoRaMac datarates definition, from DR_0 to DR_5*/
#define LORAWAN_TX_POWER TX_POWER_5							/*LoRaMac tx power definition, from TX_POWER_0 to TX_POWER_15*/
#define JOINREQ_NBTRIALS 3										  /**< Number of trials for the join request. */
DeviceClass_t g_CurrentClass = CLASS_A;					/* class definition*/
LoRaMacRegion_t g_CurrentRegion = LORAMAC_REGION_EU868;    /* Region:EU868*/
lmh_confirm g_CurrentConfirm = LMH_UNCONFIRMED_MSG;				  /* confirm/unconfirm packet definition*/
uint8_t gAppPort = LORAWAN_APP_PORT;							        /* data port*/
static lmh_param_t g_lora_param_init = {LORAWAN_ADR_ON, LORAWAN_DATERATE, LORAWAN_PUBLIC_NETWORK, JOINREQ_NBTRIALS, LORAWAN_TX_POWER, LORAWAN_DUTYCYCLE_OFF};
// Foward declaration
static lmh_callback_t g_lora_callbacks = {BoardGetBatteryLevel, BoardGetUniqueId, BoardGetRandomSeed,
                                        lorawan_rx_handler, lorawan_has_joined_handler, lorawan_confirm_class_handler, lorawan_join_failed_handler
//OTAA keys !!!! KEYS ARE MSB !!!!
uint8_t nodeDeviceEUI[8] = {0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x33, 0x33};
uint8_t nodeAppEUI[8] = {0xB8, 0x27, 0xEB, 0xFF, 0xFE, 0x39, 0x00, 0x00};
uint8_t nodeAppKey[16] = {0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88};
// ABP keys
uint32_t nodeDevAddr = 0x260116F8;
uint8_t nodeNwsKey[16] = {0x7E, 0xAC, 0xE2, 0x55, 0xB8, 0xA5, 0xE2, 0x69, 0x91, 0x51, 0x96, 0x06, 0x47, 0x56, 0x9D, 0x23};
uint8_t nodeAppsKey[16] = {0xFB, 0xAC, 0xB6, 0x47, 0xF3, 0x58, 0x45, 0xC7, 0x50, 0x7D, 0xBF, 0x16, 0x8B, 0xA8, 0xC1, 0x7C};
// Private defination
#define LORAWAN_APP_DATA_BUFF_SIZE 64                     /**< buffer size of the data to be transmitted. */
#define LORAWAN_APP_INTERVAL 20000                        /**< Defines for user timer, the application data transmission interval. 20s, value in [ms]. */
static uint8_t m_lora_app_data_buffer[LORAWAN_APP_DATA_BUFF_SIZE];            //< Lora user application data buffer.
TimerEvent_t appTimer;
static uint32_t count = 0;
void setup()
  pinMode(LED_BUILTIN, OUTPUT);
  time_t timeout = millis();
  while (!Serial)
      delay(100);
    else
      break;
  // Initialize LoRa chip.
  lora_rak4630_init();
  if (doOTAA)
    Serial.println("Type: OTAA");
  else
    Serial.println("Type: ABP");
  switch (g_CurrentRegion)
    case LORAMAC_REGION_AS923:
      break;
    case LORAMAC_REGION_AU915:
      break;
    case LORAMAC_REGION_CN470:
      break;
  case LORAMAC_REGION_CN779:
    Serial.println("Region: CN779");
    break;
    case LORAMAC_REGION_EU433:
      break;
    case LORAMAC_REGION_IN865:
      break;
    case LORAMAC_REGION_EU868:
      break;
    case LORAMAC_REGION_KR920:
      break;
    case LORAMAC_REGION_US915:
    break;
  case LORAMAC_REGION_RU864:
    Serial.println("Region: RU864");
    break;
  case LORAMAC_REGION_AS923_2:
    Serial.println("Region: AS923-2");
    break;
  case LORAMAC_REGION_AS923_3:
    Serial.println("Region: AS923-3");
    break;
  case LORAMAC_REGION_AS923_4:
    Serial.println("Region: AS923-4");
      break;
  uint32_t err_code;
  err_code = timers_init();
  if (err_code != 0)
    return;
  // Setup the EUIs and Keys
  if (doOTAA)
    lmh_setDevEui(nodeDeviceEUI);
    lmh_setAppEui(nodeAppEUI);
    lmh_setAppKey(nodeAppKey);
  else
    lmh_setNwkSKey(nodeNwsKey);
    lmh_setAppSKey(nodeAppsKey);
    lmh_setDevAddr(nodeDevAddr);
  // Initialize LoRaWan
  err_code = lmh_init(&g_lora_callbacks, g_lora_param_init, doOTAA, g_CurrentClass, g_CurrentRegion);
  if (err_code != 0)
    return;
  // Start Join procedure
  lmh_join();
void loop()
  read16(0xE9);
  delay(1000);
/**@brief LoRa function for handling HasJoined event.
  if(doOTAA == true)
  else
    Serial.println("ABP Mode");
  if (ret == LMH_SUCCESS)
    delay(1000);
    TimerStart(&appTimer);
 * @param[in] app_data  Pointer to rx data
  m_lora_app_data.buffsize = 0;
  lmh_send(&m_lora_app_data, g_CurrentConfirm);
    //Not joined, try again later
    return;
  uint32_t i = 0;
  m_lora_app_data.buffer[i++] = 'H';
  m_lora_app_data.buffer[i++] = 'e';
  m_lora_app_data.buffer[i++] = 'l';
  m_lora_app_data.buffer[i++] = 'o';
  m_lora_app_data.buffer[i++] = '!';
  m_lora_app_data.buffsize = i;
  if (error == LMH_SUCCESS)
    count++;
  else
    count_fail++;
/**@brief Function for handling user timerout event.
  send_lora_frame();
 * @details Initializes the timer module. This creates and starts application timers.
  return 0;
  Wire.write(reg);
Does anyone have faced a similar problem ? My guess is that there are some colision between the I2C reading code and the FreeRTOS.
Welcome to the forum @Alexander
The LoRa transceiver is connected through SPI and the sensor is connected through I2C, there is a conflict between the two.
As the MCU stops executing during a I2C operation, I guess there is a wrong I2C configuration (e.g missing pull-ups or wrong SDA/SCL connections). Inside the Nordic SDK that is used by the NRF52 BSP of Arduino, I experienced such behavior. If the I2C communication fails (for whatever reason), the MCU is halted with a fatal error and can be only recovered by a reset.
I suggest you try to use one of the Arduino libraries that are available for the BME680 instead of directly communicating with the BME680.
Hello Bernd,
Thanks for your welcome and your response !
Yes, i allready tried to use the RAK wireless example allready included with the board. The exemple work great when used alone, but i got problems when trying to merge with the LoRaWAN example.
I tried another way to send temperature with LoRaWAN with RAK12022 temperature PT100 sensor. Same problem, when i erge it with LoRaWAN example. Connection fail everytime.
It seems that you cannot use RAK LoRaWAN with sensors
Here the two examples merge together:
#include "RAK12022_MAX31865.h"     //http://librarymanager/All#RAK12022-MAX31865
#include <SPI.h>
#include <Wire.h>
#ifndef LED_BUILTIN
#endif
#endif
// ABP keys
#define LORAWAN_APP_INTERVAL 5000                        /**< Defines for user timer, the application data transmission interval. 20s, value in [ms]. */
uint8_t relay = 1;
uint16_t T1;
int16_t  T2, T3;
int32_t  t_fine;
const int Max_CS = SS;
MAX31865 maxTemp;
void setup()
  pinMode(WB_IO2, OUTPUT);
  digitalWrite(WB_IO2, HIGH);
  pinMode(WB_IO4, OUTPUT);
  digitalWrite(WB_IO4, HIGH);
  while (!Serial)
      delay(100);
    else
      break;
  if (doOTAA)
  else
      break;
      break;
      break;
    break;
      break;
      break;
      break;
      break;
    break;
    break;
    break;
    break;
      break;
  uint32_t err_code;
  if (err_code != 0)
    return;
  if (doOTAA)
  else
  if (err_code != 0)
    return;
  lmh_join();
  // configure rtd sensor
  if (maxTemp.begin(Max_CS, MAX31865_4WIRE, MAX31865_PT100)) //if use 2-wire,choose MAX31865_2WIRE (MAX31865_2WIRE,MAX31865_3WIRE,MAX31865_4WIRE)
    Serial.println("Found MAX31865");
  } else {
    Serial.println("MAX31865 is not connected, Please check your connections\r\n");
    while (1)
      delay(500);
  maxTemp.MAX31865_SetLowFaultThreshold(29);  // Set the low fault threshold to 29 degrees C
  maxTemp.MAX31865_SetHighFaultThreshold(34); // Set the high fault threshold to 34 degrees C
  delay(1000);
void loop()
  float mTemp, mResistance;
  uint8_t mStatus = 0;
  maxTemp.MAX31865_GetTemperatureAndStatus(mTemp, mResistance, mStatus);
  Serial.print("Resistance = ");
  Serial.print(mResistance);
  Serial.print(" Ohms,   ");
  Serial.print("Temperature = ");
  Serial.print(mTemp);
  Serial.print(" °C,   ");
  Serial.println();
  delay(500);
  if(doOTAA == true)
  else
    delay(1000);
  if(relay == 1){
    digitalWrite(WB_IO4, LOW);
    relay = 0;
  } else {
    relay = 1;
    return;
  uint32_t i = 0;
    count++;
  else
    count_fail++;
  send_lora_frame();
  float currentTemp = 0; //readBME680Temperature();
  Serial.print("Current Temp: ");
  Serial.print(currentTemp);
  Serial.println(" °C");
  return 0;
Hi Alexander,
Please add Wire.begin(); in your setup().
You are using Wire functions without initializing the I2C drivers.
Cannot belive i forgot such simple thing ^^ But wire.begin() should be included directly in the library i used first… Anyway now it’s working !
Thank’s a lot. Now the first code work properly. Didn’t try with the PT100 sensor despite it didn’t work also, maybe it need a spi.begin() also.
Yes, just to be cautious, use SPI.begin().
Many libraries I found do not call the xxx.begin().
