Issue: RAK4630 unable to flash WisCore_RAK4631_Board_Bootloader.zip
Setup: RAK4630 with WisBlock Base RAK19007
Details:
- RAK4630 is detected by mac, linux, windows
- double pressing the reset, it doesn’t show disk drive
- For the first time, I was able to flash the device using this command without any problems.: ./adafruit-nrfutil --verbose dfu serial --package rui3_nrf52840_bootloader_latest.zip --port /dev/cu.usbmodem1101 -b 115200 --singlebank --touch 1200
- then installed Firmware over WisToolBox (version is now: AT+VER=RUI_4.1.0_RAK4631)
My goal is flash Meshtastic or Meshcore firmware on this device
Question:
How can flash bootloader version WisCore_RAK4631_Board_Bootloader.zip ?
How I’m trying now flashing:
- connect WisBlock over USB and i see /dev/cu.usbmodemF8D312EC0ED91
- I go to WisToolBox and enter the command: AT+BOOT
- The device tells me that it disconnected and reconnected.
- And i see now again the device /dev/cu.usbmodemF8D312EC0ED91
- then I’ll call the command: ./adafruit-nrfutil-macos --verbose dfu serial --package WisCore_RAK4631_Board_Bootloader.zip -p /dev/cu.usbmodemF8D312EC0ED91 -b 115200 --singlebank
- After a moment, the following list displays
Upgrading target on /dev/cu.usbmodemF8D312EC0ED91 with DFU package /Users/donald/Downloads/RAK/WisCore_RAK4631_Board_Bootloader.zip. Flow control is disabled, Single bank, Touch disabled
Opened serial port /dev/cu.usbmodemF8D312EC0ED91
Starting DFU upgrade of type 3, SoftDevice size: 151016, bootloader size: 39000, application size: 0
Sending DFU start packet
Timed out waiting for acknowledgement from device.
Sending DFU init packet
Failed to upgrade target. Error is: Attempting to use a port that is not open
File “main.py”, line 296, in serial
File “dfu/dfu.py”, line 226, in dfu_send_images
File “dfu/dfu.py”, line 203, in _dfu_send_image
File “dfu/dfu_transport_serial.py”, line 155, in send_init_packet
File “dfu/dfu_transport_serial.py”, line 241, in send_packet
File “serial/serialposix.py”, line 615, in write
serial.serialutil.PortNotOpenError: Attempting to use a port that is not open
Possible causes:
- Selected Bootloader version does not match the one on Bluefruit device.
Please upgrade the Bootloader or select correct version in Tools->Bootloader. - Baud rate must be 115200, Flow control must be off.
- Target is not in DFU mode. Ground DFU pin and RESET and release both to enter DFU mode.
