RAK4630 modules dying for no apparent reason
I’m looking at my second dead board. The first one worked for a couple days, and then stopped talking on meshtastic and bluetooth. The second one worked for a couple weeks, then dies the same way.
On both boards, I reflashed the boards using the process of putting the uf2 file in the USB drive created by the module. (firmware-rak4631-2.4.2.5b45303. Post flash the device does not show up on bluetooth or wifi, or meshtastic.
FWIW neither board was ever powered up without the antenna connected.
Battery voltage is 4.096 volts, and I have tried removing and re-applying power.
Welcome to RAK forum @dbvanhorn ,
The situation you have is not really the first case. Even on Meshtastic discourse forum and discord, there are many concerns about Meshtastic nodes suddenly stop working and it commonly happen few days after outdoor deployment/installation.
It appears to me that there could be corruption on the flash of your module (although the bootloader section is still working since you can still drag a uf2 file).
What you can do is try to upload the Meshtastic_nRF52_factory_erase to hopefully clear any flash related issue (take note that you still need to open a terminal and hit enter to perform this erase and not only dragging the file).
Why this happen? There is corruption in flash that can happen during reset or when voltage supply is marginal/low. This is also the reason why it happens only in remote deployments and after few days.
This is the last update I can see on Meshtasitc github (issue link) and some possible fix on this issue. However, since it is likely to break some core function of the FW (as I understand it), the plan is to include it release of Meshtastic V3.
Until then what you can do is ensure that power supply is stable on modules. This means you need to have proper cutoff circuit on the batteries and also have good solar charging setup in case solar powered.
I also recommend to have external debugger/programmer like Jlink or RAKDAP1 so you can revived your bricked modules.
Well, I can’t speak to the circuit design. It’s on a carrier board branded “Wisblock”
I am very doubtful that the power is going low enough to cause those issues, but given lightning in the area, an EMP caused reset is rather likely. I don’t have the schematics or I’d diagnose that. I suspect the reset circuit impedance is too high (high pullup resistor, small cap) for this sort of use.
But this begs the question, why would anyone store volatile data like this in non-volatile memory anyway. Flash/EE/whatever has a finite number of write cycles anyway, in addition to all the power and timing constraints you noted. A volatile message log belongs in RAM. External serial RAM is cheap, and if a message gets scrambled, or if the whole thing gets scrambled, who cares?
This can be a good discussion with the Meshtastic developers. They are active in github/discord on this topic but I am not fully update.
If you think you have stable supply, I agree that maybe transient electrical pulse/noise can introduce the reset. As for the solution, you can reenforce it via hardware (lower COG capacitor in reset pin, earthed metal enclosure, etc.) but I think the fix should be the software. Like if the module resets 1000x, there should be no lockup or any flahs related issue that can happen.
I was part of the team that engineered the Verifone credit card terminals in the early 80’s. Been doing embedded systems ever since.
It costs a little more in hardware, software, and design effort to get it right, but it’s worth it.
I had a very similar experience. I started trying out Meshtastic with a T-beam, but liked the features of the RAK 4361 so I got a 19001 kit. After it had been working for a week or so, I was trying a few things with it, and then lost the Bluetooth connection. I tried connecting it via series using client.meshtastic.org and couldn’t read anything from the unit. I tried reflashing it using flasher.meshtastic.org. I could put it in DFU mode, but when I tried to drag the UF2 file to the D: drive, it would fail part way through. Before I put it in DFU mode, the series connection was lost and then reset with every flash of the green LED on the 19001 board. I tried the factory erase on the 6340, but couldn’t install that file either. – I thought I might have done something to break the processor (nothing so blatant as powering it without an antenna!), so I ordered a barebones 19007 Wis Block kit which worked fine. I transferred the 4360 to the old 19001 and it worked fine for two weeks. I left it untouched and powered via USB. Then yesterday, there was no Bluetooth signal, and it had exactly the same symptoms as before. It seemed to a completely random failure as far as I could tell.
I noticed that carlrowan said (carlrowan, post:2, topic:13215), “take note that you still need to open a terminal and hit enter to perform this erase and not only dragging the file,” and also, “I also recommend to have external debugger/programmer like Jlink or RAKDAP1 so you can revived your bricked modules.”
That sounds like what I need to do, but I’m too much of a novice to know how to do those. Can you point me in the direction of some detailed instructions?”
Thanks!
