I have some RAK4630 modules that are only accessible with a USB interface for updating. Not possible to access programming pins with JLINK or RAKDAP1.
Some time ago, I develop an script for updating them in PC with Windows 11:
- Switch to AT mode (since they are configured with
RAK_CUSTOM_MODE) - Set to boot mode with AT+BOOT
- Run nrfutil tool to update with compiled file in .zip
Now, this is not working anymore, nrfutil DFU upload consistently gets stuck at approximately 60% of the transfer process. As process is not completed, application becomes corrupted. I managed to recover the module by using the VS Code IDE with Arduino extension (arduino-cli upload). From the IDE, it always works.
Tests performed
- Running from the terminal the same arduino-cli upload command with and without elevated privileges:
arduino-cli upload --fqbn rak_rui:nrf52:WisCoreRAK4631Board --port COM6 - Using three different units.
- Using nrfutil alone. Downloaded from: RAKWireless docs.
- In a different PC running Ubuntu and using the nrfutil installed with
pip3. - Tried different RUI3 release.
- Killing conflicting processes (e.g. VS Code, Arduino IDE, serial monitors, terminals, etc.).
- Lowering the serial baud rate.
- Tried different USB cables.
In all cases, it fails at about 60% of the process, so it starts programming but never ends correctly. As mentioned before, only working from VS Code IDE, probably from Arduino IDE as well but I haven’t checked.
Questions:
- Why does arduino-cli upload work flawlessly while nrfutil DFU hangs at 60%?
- What upload mechanism does arduino-cli use that differs from nrfutil DFU?
- Are there known timing issues with the RAK4630 bootloader specific to nrfutil?
- Should I be using a different version of nrfutil or different upload parameters?
- Is the 60% failure point indicative of a specific issue (e.g., memory page, flash sector boundary)?
Terminal output:
2026-02-10 13:23:52,965 Using board at serial port: COM6
2026-02-10 13:23:52,972 Sending Application image.
2026-02-10 13:23:56,480 Serial: Set Packet Receipt Notification 0
2026-02-10 13:23:56,482 Sending init packet...
2026-02-10 13:23:56,482 Serial: Selecting Object: type:1
2026-02-10 13:23:56,483 Serial: Object selected: max_size:512 offset:0 crc:0
2026-02-10 13:23:56,484 Serial: Streaming Data: len:141 offset:0 crc:0x00000000
2026-02-10 13:23:56,675 Sending firmware file...
2026-02-10 13:23:56,676 Serial: Selecting Object: type:2
2026-02-10 13:23:56,677 Serial: Object selected: max_size:4096 offset:0 crc:0
2026-02-10 13:23:56,761 Serial: Streaming Data: len:4096 offset:0 crc:0x00000000
2026-02-10 13:23:56,918 Serial: Streaming Data: len:4096 offset:4096 crc:0x47DC8DB3
2026-02-10 13:23:57,074 Serial: Streaming Data: len:4096 offset:8192 crc:0xE78B8836
2026-02-10 13:23:57,232 Serial: Streaming Data: len:4096 offset:12288 crc:0x1A50BC58
2026-02-10 13:23:57,389 Serial: Streaming Data: len:4096 offset:16384 crc:0xF2D3FF75
2026-02-10 13:23:57,546 Serial: Streaming Data: len:4096 offset:20480 crc:0xAC991E42
2026-02-10 13:23:57,703 Serial: Streaming Data: len:4096 offset:24576 crc:0x18B96099
2026-02-10 13:23:57,860 Serial: Streaming Data: len:4096 offset:28672 crc:0xFA9A2DDE
2026-02-10 13:23:58,017 Serial: Streaming Data: len:4096 offset:32768 crc:0x07373EFD
2026-02-10 13:23:58,174 Serial: Streaming Data: len:4096 offset:36864 crc:0xB6766845
2026-02-10 13:23:58,331 Serial: Streaming Data: len:4096 offset:40960 crc:0xB8C6393E
2026-02-10 13:23:58,488 Serial: Streaming Data: len:4096 offset:45056 crc:0x1E9FAC7E
2026-02-10 13:23:58,645 Serial: Streaming Data: len:4096 offset:49152 crc:0xEEC55ECB
2026-02-10 13:23:58,802 Serial: Streaming Data: len:4096 offset:53248 crc:0x7F23EFDE
2026-02-10 13:23:58,958 Serial: Streaming Data: len:4096 offset:57344 crc:0xACA75382
2026-02-10 13:23:59,115 Serial: Streaming Data: len:4096 offset:61440 crc:0x9A934FD7
2026-02-10 13:23:59,272 Serial: Streaming Data: len:4096 offset:65536 crc:0x670D90F3
2026-02-10 13:23:59,429 Serial: Streaming Data: len:4096 offset:69632 crc:0x6C06BABE
2026-02-10 13:23:59,587 Serial: Streaming Data: len:4096 offset:73728 crc:0x75E61D80
2026-02-10 13:23:59,744 Serial: Streaming Data: len:4096 offset:77824 crc:0x0D3ED0DC
2026-02-10 13:23:59,901 Serial: Streaming Data: len:4096 offset:81920 crc:0x22AB4BA7
2026-02-10 13:24:00,057 Serial: Streaming Data: len:4096 offset:86016 crc:0xC1A93B17
2026-02-10 13:24:00,214 Serial: Streaming Data: len:4096 offset:90112 crc:0xF39F6CDB
2026-02-10 13:24:00,372 Serial: Streaming Data: len:4096 offset:94208 crc:0x52E7DF2B
2026-02-10 13:24:00,529 Serial: Streaming Data: len:4096 offset:98304 crc:0x13A763C8
2026-02-10 13:24:00,686 Serial: Streaming Data: len:4096 offset:102400 crc:0xCF840E31
2026-02-10 13:24:00,842 Serial: Streaming Data: len:4096 offset:106496 crc:0xF5BD7E3A
2026-02-10 13:24:00,999 Serial: Streaming Data: len:4096 offset:110592 crc:0x0D0F13DB
2026-02-10 13:24:01,156 Serial: Streaming Data: len:4096 offset:114688 crc:0x62ECFF6C
2026-02-10 13:24:01,313 Serial: Streaming Data: len:4096 offset:118784 crc:0xEFA83522
2026-02-10 13:24:01,470 Serial: Streaming Data: len:4096 offset:122880 crc:0xF1572503
2026-02-10 13:24:01,627 Serial: Streaming Data: len:4096 offset:126976 crc:0xC089E2F1
2026-02-10 13:24:01,784 Serial: Streaming Data: len:4096 offset:131072 crc:0x28EAEDDC
2026-02-10 13:24:01,941 Serial: Streaming Data: len:4096 offset:135168 crc:0x9C11C071
2026-02-10 13:24:02,098 Serial: Streaming Data: len:4096 offset:139264 crc:0xC2C3DB1B
2026-02-10 13:24:02,254 Serial: Streaming Data: len:4096 offset:143360 crc:0xF9F2ACD9
2026-02-10 13:24:02,411 Serial: Streaming Data: len:4096 offset:147456 crc:0x20E1CCAA
2026-02-10 13:24:02,567 Serial: Streaming Data: len:4096 offset:151552 crc:0x82CEF4E0
2026-02-10 13:24:02,724 Serial: Streaming Data: len:4096 offset:155648 crc:0x74D20EC2
2026-02-10 13:24:02,882 Serial: Streaming Data: len:4096 offset:159744 crc:0x093FA7C2
2026-02-10 13:24:03,039 Serial: Streaming Data: len:4096 offset:163840 crc:0x94E301F1
2026-02-10 13:24:03,196 Serial: Streaming Data: len:4096 offset:167936 crc:0x6A9153E6
2026-02-10 13:24:03,353 Serial: Streaming Data: len:4096 offset:172032 crc:0x5B16946A
2026-02-10 13:24:03,510 Serial: Streaming Data: len:4096 offset:176128 crc:0x79EF98EC
2026-02-10 13:24:03,667 Serial: Streaming Data: len:4096 offset:180224 crc:0x999C5E11
2026-02-10 13:24:03,824 Serial: Streaming Data: len:4096 offset:184320 crc:0x64AD589F
2026-02-10 13:24:03,987 Serial: Streaming Data: len:4096 offset:188416 crc:0x50B32268
File "nordicsemi\dfu\dfu_transport_serial.py", line 123, in send_message
File "serial\serialwin32.py", line 317, in write
serial.serialutil.SerialException: WriteFile failed (PermissionError(13, 'The device does not recognize the command.', None, 22))
During handling of the above exception, another exception occurred:
File "nordicsemi\__main__.py", line 1545, in <module>
File "click\core.py", line 1137, in __call__
File "click\core.py", line 1062, in main
File "click\core.py", line 1668, in invoke
File "click\core.py", line 1404, in invoke
File "click\core.py", line 763, in invoke
File "nordicsemi\__main__.py", line 1063, in serial
File "nordicsemi\__main__.py", line 980, in do_serial
File "nordicsemi\dfu\dfu.py", line 127, in dfu_send_images
File "nordicsemi\dfu\dfu.py", line 100, in _dfu_send_image
File "nordicsemi\dfu\dfu_transport_serial.py", line 301, in send_firmware
File "nordicsemi\dfu\dfu_transport_serial.py", line 466, in __stream_data
File "nordicsemi\dfu\dfu_transport_serial.py", line 125, in send_message
pc_ble_driver_py.exceptions.NordicSemiException: Writing to serial port failed: WriteFile failed (PermissionError(13, 'The device does not recognize the command.', None, 22)). If MSD is enabled on the target device, try to disable it ref. https://wiki.segger.com/index.php?title=J-Link-OB_SAM3U
[52512] Failed to execute script '__main__' due to unhandled exception!
CompletedProcess(args=['C:\\Users\\carlosgalindo\\AppData\\Local\\Arduino15\\packages\\rak_rui\\tools\\pc-nrfutil\\v6.1.7/nrfutil', '-v', '-v', '-v', 'dfu', 'serial', '--package', 'C:\\Users\\carlosgalindo\\workspaces\\Arduino\\mbox24-rak4630-lorawan/build/mbox24-rak4630-lorawan.ino.zip', '-p', 'COM6', '-b', '115200'], returncode=1)
