As i have some issues with SX126x-Arduino library, I would like to try to use lmic, but i can’t find any schematic of RAK4630. I only searched in SX126x-Arduino lib and found this informations :
SPIClass SPI_LORA(NRF_SPIM2, 45, 43, 44);
// _hwConfig.CHIP_TYPE = SX1262; // Chip type, SX1261 or SX1262
_hwConfig.PIN_LORA_RESET = 38; // LORA RESET
_hwConfig.PIN_LORA_NSS = 42; // LORA SPI CS
_hwConfig.PIN_LORA_SCLK = 43; // LORA SPI CLK
_hwConfig.PIN_LORA_MISO = 45; // LORA SPI MISO
_hwConfig.PIN_LORA_DIO_1 = 47; // LORA DIO_1
_hwConfig.PIN_LORA_BUSY = 46; // LORA SPI BUSY
_hwConfig.PIN_LORA_MOSI = 44; // LORA SPI MOSI
_hwConfig.RADIO_TXEN = 39; // LORA ANTENNA TX ENABLE (e.g. eByte E22 module)
_hwConfig.RADIO_RXEN = 37; // LORA ANTENNA RX ENABLE (e.g. eByte E22 module)
_hwConfig.USE_DIO2_ANT_SWITCH = true; // LORA DIO2 controls antenna
_hwConfig.USE_DIO3_TCXO = true; // LORA DIO3 controls oscillator voltage (e.g. eByte E22 module)
_hwConfig.USE_DIO3_ANT_SWITCH = false; // LORA DIO3 controls antenna (e.g. Insight SIP ISP4520 module)
_hwConfig.USE_RXEN_ANT_PWR = true; // RXEN is used as power for antenna switch
Buts it’s a bit confusing : no DIO0, or DIO2 or DIO3 … And I can’t find any schematic ib documentation.
