I am using the RAK4631 with the Arduino IDE (2.3.3).
I am trying to process a downlink message to change the interval. When I change LORAWAN_APP_INTERVAL to a uint32_t the last message I see is Sending frame now…
What type should I be using for the TimerSetValue?
Also is there a way to write that to flash so I do not have to send a downlink message everytime the device comes online?
I am mostly using the Enviromental_Monitoring from WisBlock Kit 4 along with the Arduino IDE 2.3.3. I also attached 3ghz motion IO sensor and pulled the code in from that example.
I was able to solve the problem by making the LORAWAN_APP_INTERVAL a static uint32_t. When it was not static it would stop once it attempted to send the first message.
On the writing to flash question I am going to open a new topic.
