Hello, I want to this: My system will work in a period, my loop section has a period with millis() function. But it didn’t work. I want to this system with timer interrupt. Can you give me a Timer İnterrupt codes for RAK4630. When I use example timer interrupt code for arduino, it’s not work.
Please help this subject…
Hi @yohyaVv
Can you share your code? I don’t understand what is not working there.
For RAK4630, you can use the SoftwareTimer Class to trigger a function to run in a specified interval.
Here is a simple example how to use it:
This is an example for our nRF52 based Bluefruit LE modules
Pick one up today in the adafruit shop!
Adafruit invests time and resources providing this open source code,
please support Adafruit and open-source hardware by purchasing
products from Adafruit!
MIT license, check LICENSE for more information
All text above, and the splash screen below must be included in
any redistribution
#include <Arduino.h>
#include <Adafruit_TinyUSB.h> // for Serial
/* SoftwareTimer is a helper class that uses FreeRTOS software timer
* to invoke callback. Its periodic timing is flexible as opposed to
* hardware timer and cannot be faster than rtos's tick which is configured
* at ~1 ms interval.
* If you need an strict interval timing, or faster frequency, check out
* the hw_systick sketch example that use hardware systick timer.
* http://www.freertos.org/RTOS-software-timer.html
SoftwareTimer blinkTimer;
void setup()
// Configure the timer with 1000 ms interval, with our callback
blinkTimer.begin(1000, blink_timer_callback);
// Start the timer
blinkTimer.start();
void loop()
// do nothing here
* Software Timer callback is invoked via a built-in FreeRTOS thread with
* minimal stack size. Therefore it should be as simple as possible. If
* a periodically heavy task is needed, please use Scheduler.startLoop() to
* create a dedicated task for it.
* More information http://www.freertos.org/RTOS-software-timer.html
void blink_timer_callback(TimerHandle_t xTimerID)
// freeRTOS timer ID, ignored if not used
(void) xTimerID;
digitalToggle(LED_RED);
