too many initializers for ‘lmh_callback_t’ {aka ‘lmh_callback_s’}
I understand that it’s difficult to mantain a big repository like this, but where i can find a simple PING test for verifiy where is the problem on my implementation?
Also on the gateway the image shipped with the gateway D4D, the apt-get update doesn’t work.
I’m not sure if you’ve tried again and got the same error or if you will be trying again.
It does seem like a simplistic solution, but if you used the stock firmware, then apt-get update not working isn’t really a RAK thing, more a Raspberry Pi thing and, as I suggested, with networks & repro’s, anything could have been happening at the point in time you tried to retrieve the update list.
Thanks for reply, i’ve tried many times, the last one 5 min ago. I dont think it’s a rpi thing, because i’ve bought two D4D gateway, and both do the problem! ( tested on two different network). I think that the problem may be a config shipped with the stock fw.
Ah, you mean the RAK firmware, not the vanilla RPi firmware, my apologies.
I haven’t seen this issue, there was one with DNS last autumn but I haven’t setup a gateway with the latest RAK download of late apart from the RAK7246 which is a different build. As I’ve got other gateways to deploy shortly (once we can get to them, Covid!) I can give it a try here.
