What product do you wish to discuss? RAK4631, RAK3372, RAK11200, RAK11310, RAK11722? The subject RAK4631 core + RAK19007 base + RAK13010 SDI-12 IO module works okay. But I tried to use pinMode (WB_IO1, OUTPUT) to send coded pulses for various changes in state of the LoRaWAN and SDI-12 sensor readings to an externally mounted IP67 LED. This won’t output a signal even if I simply try to turn the LED on/off after void setup( ) via void loop() code. What kind of conflict might be occurring that I am missing? And if this is an interrupt or SDI-12/ LoRaWAN conflict issue, is there a way to work around this? The reason I am asking is that I am porting this to a solar powered battery charger enclosure with an external IP67 reset switch and the indicator to provide external status.
What firmware are you using? (RUI3 or Arduino BSP or other IDE (e.g. STM32CubeIDE)? I’m using the Arduino BSP and IDE with UF2 Bootloader 0.4.4
Model: WisBlock RAK4631 Board
Date: Jun 17 2026
Ver: 0.4.4
SoftDevice: S140 6.1.1 and appropriate Arduino RAKwireless libraries. -
What firmware version? Can it be obtained with AT+VER=?
Computer OS? (MacOS, Linux, Windows) Windows 10
What Computer OS version? Latest Windows 10 with extended security updates
How often does the problem happen?
How can we replicate the problem? I don’t think so, because you folks don’t have any similar SDI-12 sensors.
Provide source code if custom firmware is used or link to example if RAKwireless example code is used.
