Just finished updating the code and testing it again and it works fine on my side.
@carlrowan
I know you can test on EU868, can you try? I cannot find any problems when testing on AS923-3.
@carlrowan
Hi @jpmeijers ,
I tested EU868 on both Chirpstack and TTS (TTN V3).
It worked all fine from MAC V1.0.2 up to MAC V1.0.4.
Looking at your TTS console, you have issues on Uplink is a duplicate and DevNonce has already been used.
Can you try to rejoining using different appkey? I am thinking the devnonce is already monitored by the TTS backend.
Hi @carlrowan
I had the same thought, but the duplicate uplink and used nonce are both related to me having multiple gateways around. Some of the gateways have high latency. This causes the same uplink to be seen multiple times by the network. The delayed uplinks are correctly seen as duplicates, and therefore also already used nonces.
This however do not explain why this wisblock takes a full minute after startup before it starts joining.
I’ll download fresh copies of the BSP and sx126x library and test again.
I tried again today, and I’m seeing the same problem still.
The LoRaWan_OTAA_ABP example joins immediately after startup and then transmits uplinks periodically as expected:
11:42:39.371 -> =====================================
11:42:39.371 -> Welcome to RAK4630 LoRaWan!!!
11:42:39.371 -> Type: OTAA
11:42:39.371 -> Region: EU868
11:42:39.371 -> <LMH> OTAA
11:42:39.371 -> DevEui=7D-80-DA-86-A8-3D-4D-85
11:42:39.371 -> DevAdd=00000000
11:42:39.371 -> AppEui=7D-80-DA-86-A8-3D-4D-85
11:42:39.371 -> AppKey=7D-80-DA-86-A8-3D-4D-85-7D-80-DA-86-A8-3D-4D-85
11:42:39.428 -> <LMH> Selected subband 1
11:42:39.528 -> <LM> OnRadioTxDone
11:42:39.528 -> <LM> OnRadioTxDone => RX Windows #1 4989 #2 5995
11:42:39.528 -> <LM> OnRadioTxDone => TX was Join Request
11:42:44.599 -> <LM> OnRadioRxDone
11:42:44.599 -> <LM> OnRadioRxDone => FRAME_TYPE_JOIN_ACCEPT
11:42:44.599 -> OTAA Mode, Network Joined!
11:43:05.587 -> Sending frame now...
11:43:05.620 -> lmh_send ok count 1
11:43:06.913 -> <LM> OnRadioTxDone
11:43:06.913 -> <LM> OnRadioTxDone => RX Windows #1 5030 #2 5995
11:43:13.112 -> <LM> OnRadioRxDone
11:43:13.112 -> <LM> OnRadioRxDone => FRAME_TYPE_DATA_(UN)CONFIRMED_DOWN
11:43:13.112 -> <LM> Calling MacMcpsIndication
11:43:25.576 -> Sending frame now...
11:43:25.609 -> lmh_send ok count 2
11:43:25.709 -> <LM> OnRadioTxDone
11:43:25.709 -> <LM> OnRadioTxDone => RX Windows #1 4991 #2 5995
11:43:30.782 -> <LM> OnRadioRxDone
11:43:30.782 -> <LM> OnRadioRxDone => FRAME_TYPE_DATA_(UN)CONFIRMED_DOWN
11:43:30.782 -> <LM> Calling MacMcpsIndication
Note in the above log how it takes 5 seconds for the device to join.
The RAK4631_DeepSleep_LoRaWAN example (with if (!xTaskCreate(loraTask,... commented out) takes a minute before it tries to join, the join seems to fail, and then it gets stuck, never transmitting again:
11:34:51.280 -> =====================================
11:34:51.280 -> RAK4631 LoRaWan Deep Sleep Test
11:34:51.313 -> <BRD> SyncWord = 2414
11:34:51.313 -> <BRD> LoRa Task started
11:34:51.313 -> <LMH> OTAA
11:34:51.313 -> DevEui=7D-80-DA-86-A8-3D-4D-85
11:34:51.313 -> DevAdd=00000000
11:34:51.313 -> AppEui=7D-80-DA-86-A8-3D-4D-85
11:34:51.313 -> AppKey=7D-80-DA-86-A8-3D-4D-85-7D-80-DA-86-A8-3D-4D-85
11:34:51.379 -> <LMH> Selected subband 1
11:34:51.379 -> Start network join request
11:35:55.532 -> LoRaWan init success
Arduino IDE 1.8.13
RAKwireless nRF Boards 0.21.20
SX126x-Arduino 2.0.0
As a sanity check I took a fresh RAK4631 out of a packet, updated the firmware, and wrote the DeepSleep example to it. The behaviour is the same, where a join only happens after 1 minute, and the firmware hangs after printing LoRaWan init success.
New board’s output:
17:19:59.307 -> =====================================
17:19:59.307 -> RAK4631 LoRaWan Deep Sleep Test
17:19:59.354 -> <BRD> SyncWord = 2414
17:19:59.354 -> <BRD> LoRa Task started
17:19:59.354 -> <LMH> OTAA
17:19:59.354 -> DevEui=54-6A-AE-19-3E-E5-F2-FD
17:19:59.354 -> DevAdd=00000000
17:19:59.354 -> AppEui=54-6A-AE-19-3E-E5-F2-FD
17:19:59.354 -> AppKey=54-6A-AE-19-3E-E5-F2-FD-54-6A-AE-19-3E-E5-F2-FD
17:19:59.421 -> <LMH> Selected subband 1
17:19:59.421 -> Start network join request
17:21:04.340 -> LoRaWan init success
TTNv3 non-verbose logs
Because the new board is not in its enclosure, I am able to see the LEDs better. I’m seeing the RED LED pulsing brighter sometimes. This is in the current state after LoRaWan init success is printed.
Hello @jpmeijers @carlrowan
The red LED is the charge indicator, it is not controlled by the MCU, only by the charger chip. It flickers while charging or if no battery is attached.
More important, I found the 1 minute delay.
In lora_handler.cpp look for
static lmh_param_t lora_param_init = {LORAWAN_ADR_OFF, DR_3, LORAWAN_PUBLIC_NETWORK, JOINREQ_NBTRIALS, LORAWAN_DEFAULT_TX_POWER, LORAWAN_DUTYCYCLE_ON};
And change LORAWAN_DUTYCYCLE_ON to LORAWAN_DUTYCYCLE_OFF.
This removes the 1 minute delay for me.
Why on EU868 LORAWAN_DUTYCYCLE_ON triggers a 1 minute delay is something I still have to find out. It looks like the DutyCycle is enforced and the sending is delayed by 1 minute. Looking into it right now.
FWIW, I’m undergoing a similar exercise in understanding why someone else’s module based on the Semtech code has similar behaviour issues.
@nmcc My library is based on Semtech’s code as well.
So far I could only find that if DutyCycle is enabled, it delays the first join request by 65 seconds. Still trying to find out why it does it. And it seems to be linked to EU868.
My ‘mess’ is that it joins promptly but then the module concerned silently drops the first uplink if it’s too soon after the join. And then there is another mandatory delay required before I can send the second uplink.
This makes sending a boot/config/status message and then first set of sensor data a bit tricky.
I either want feedback to know it didn’t actually send or to know exactly what delay the firmware can tolerate - but it’s not RAK so it’s not an issue for here as such, more of general concern for those using LoRaMac-node.
Chaning to LORAWAN_DUTYCYLE_OFF indeed makes the JoinRequest being sent much sooner. But the join still doesn’t succeed. One can also see that the LoRaWan init success is not printed to Serial (at least not within 10 minutes).
18:55:08.555 -> =====================================
18:55:08.555 -> RAK4631 LoRaWan Deep Sleep Test
18:55:08.589 -> <BRD> SyncWord = 2414
18:55:08.589 -> <BRD> LoRa Task started
18:55:08.589 -> <LMH> OTAA
18:55:08.589 -> DevEui=54-6A-AE-19-3E-E5-F2-FD
18:55:08.589 -> DevAdd=00000000
18:55:08.589 -> AppEui=54-6A-AE-19-3E-E5-F2-FD
18:55:08.589 -> AppKey=54-6A-AE-19-3E-E5-F2-FD-54-6A-AE-19-3E-E5-F2-FD
18:55:08.655 -> <LMH> Selected subband 1
18:55:08.655 -> Start network join request
// no further output for >10 minutes
To eliminate another variable I am now in a location with only a single gateway connected to TTN. That also didn’t change the behaviour.
The normal example joins immediately, and joins successfully. Only the DeepSleep example has the issue - and also only since the the BSP and sx126x update. Both of these examples use the same lora configuration and library. Why does the deepsleep fail and the normal one not? Has to be the deepsleep code?
Does the DeepSleep example disable the timer used for the LoRaWAN timing? Or maybe change its period?
Normal example output:
19:06:17.486 -> =====================================
19:06:17.486 -> Welcome to RAK4630 LoRaWan!!!
19:06:17.486 -> Type: OTAA
19:06:17.486 -> Region: EU868
19:06:17.519 -> <LMH> OTAA
19:06:17.519 -> DevEui=54-6A-AE-19-3E-E5-F2-FD
19:06:17.519 -> DevAdd=00000000
19:06:17.519 -> AppEui=54-6A-AE-19-3E-E5-F2-FD
19:06:17.519 -> AppKey=54-6A-AE-19-3E-E5-F2-FD-54-6A-AE-19-3E-E5-F2-FD
19:06:17.585 -> <LMH> Selected subband 1
19:06:17.654 -> <LM> OnRadioTxDone
19:06:17.654 -> <LM> OnRadioTxDone => RX Windows #1 4989 #2 5995
19:06:17.654 -> <LM> OnRadioTxDone => TX was Join Request
19:06:22.731 -> <LM> OnRadioRxDone
19:06:22.731 -> <LM> OnRadioRxDone => FRAME_TYPE_JOIN_ACCEPT
19:06:22.731 -> OTAA Mode, Network Joined!
Hi @jpmeijers ,
Can you send me the sketch that you are using at [email protected]? I’ll change the EUI/Key and try it.
Mine is working ok and not stopping. It does then the 2minute interval uplink. Though I have the same issue on 1minute delay before joining but it is gone now when the dutycyle is set to off.
It tested it in two RAK4631 (using same keys/EUI).
Hi @carlrowan
I’ve sent it to you, although it is just the example with the lorawan task commented out, serial debug enabled, and my keys added. But please try it on your side and let me know.
I’ve also included a compiled hex version which you can try. It is possible that we are using different versions of the toolchain, even though mine says it is fully updated.
Hi @jpmeijers ,
I tried your example and it doesn’t work to me. Got the same issue you experienced. Have you tried the modifications suggested above by @beegee ? Those works for me and solve the issue. Sorry I wasn’t able to track the changes and I thought we are aligned in the code.
Here is the code that works for me. Can you try? You can change the EUIs and Key.
Hi @jpmeijers
I looked into the source code you sent to @carlrowan.
There is one line, that I asked you to change, but I think you missed it:
Running the code without this line commented out results in hanging. Commenting it or removing it and it worked for me.
Btw. I updated the WisBlock Repo example 4 days ago.
@beegee ahh yes, I thought I was only supposed to comment out the xTaskCreate lines. Thanks for spotting that mistake!
Repo update: Arduino hasn’t picked up an update yet. I also did not see any changes to GitHub - RAKWireless/RAKwireless-Arduino-BSP-Index: RAKwireless BSP Support for the Arduino Board Manager. Should I manually install the update from Github?
Also commenting out the attachInterrupt in addition to the xTaskCreate indeed solves the problem where the firmware stops after the JoinRequest. That solves the major part of this issue.
The one minute delay when duty cycle is enabled is however still a concern. Also strange that this is only a problem with DeepSleep and not the Normal example.
A strange thing that I see here is that OnRadioRxDone => FRAME_TYPE_JOIN_ACCEPT is only printed before the next TX 2 minutes later, not directly after the JoinRequest.
08:58:24.044 -> =====================================
08:58:24.044 -> RAK4631 LoRaWan Deep Sleep Test
08:58:24.077 -> <BRD> SyncWord = 2414
08:58:24.077 -> <BRD> LoRa Task started
08:58:24.077 -> <LMH> OTAA
08:58:24.077 -> DevEui=54-6A-AE-19-3E-E5-F2-FD
08:58:24.077 -> DevAdd=00000000
08:58:24.077 -> AppEui=54-6A-AE-19-3E-E5-F2-FD
08:58:24.077 -> AppKey=54-6A-AE-19-3E-E5-F2-FD-54-6A-AE-19-3E-E5-F2-FD
08:58:24.143 -> <LMH> Selected subband 1
08:58:24.143 -> Start network join request
08:59:29.095 -> LoRaWan init success
08:59:29.161 -> <LM> OnRadioTxDone
08:59:34.149 -> <LM> OnRadioTxDone => RX Windows #1 4989 #2 5995
08:59:34.149 -> <LM> OnRadioTxDone => TX was Join Request
08:59:34.248 -> <LM> OnRadioRxDone
09:01:34.251 -> <LM> OnRadioRxDone => FRAME_TYPE_JOIN_ACCEPT
09:01:34.251 -> OTAA joined and got dev address 260B0721
09:01:34.748 -> Timer wakeup
09:01:34.748 -> LoRaWan package sent successfully
09:01:34.947 -> <LM> OnRadioTxDone
09:01:39.952 -> <LM> OnRadioTxDone => RX Windows #1 4995 #2 5995
09:01:43.898 -> <RADIO> RadioIrqProcess => IRQ_RX_TX_TIMEOUT
09:01:43.898 -> <LM> OnRadioRxTimeout
The examples in the Arduino BSP will only be updated when I release the next version of the BSP (which is in testing right now). I am talking about our WisBlock examples repo.
This is not strange. Serial is linked to the loop() task. If the loop() task goes into sleep, there is no Serial output until the loop wakes up. This is an FreeRTOS thing and I cannot change it.
A (very bad) work-around is to put a delay(100) after the Serial.println() in the callbacks. This gives the Serial time to send the data before the loop() goes back to sleep.
Again, not strange. The LoRaWAN_OTAA_ABP.ino has LORAWAN_DUTYCYCLE_OFF as default. If you change it to LORAWAN_DUTYCYCLE_ON you see the same delay.
Ahh yes I see that now.
Ok, I’ll mark this issue as solved. Hopefully we can find the cause for the 60s delay with duty cycle on soon.
Thanks @beegee and @carlrowan
Adding Serial.flush(); after every Serial.println in lora_handler.cpp seems to work.
