Hello.
I am having a issue with the module in Malasia.
I have discovered that the library from Semtech for this country (AS923-1) is wrong, only two channels are correct and I needed to modify to allow the 8 channels that are usable in Malasia, I will “git push” and see if the accept or no.
The second issue I have is that when I send TX data over lorawan it returns sometimes -1, failed, after that I cannot send data anymore.
If I query the status I get the following:
LMH_ERROR_STATUS=0
LMH_JOIN_STATUS=1
Apparently it is all ok.
I tried to lmh_join() again but it hangs and the watchdog triggers (thanks dog).
I have been trying to manage this via software, maybe unjoining the network and joining again or like but I have not seen any function to do that.
Only solution for now is just reboot and start again.
Anyone knows what the issue could be??
