I am planning to purchase 5 additional RAK4631 units.
We are going to set the settings to 4 transmitters and 1 receiver.
So can I get RSSI values of 4 transmitters from one receiver?
(Example output from receiver) EX. TX1 RSSI: -64, TX2 RSSI: -32, TX3 RSSI: -17, TX4 RSSI: -89
Welcome to the forum @park
Yes, you will see the RSSI and SNR levels of the 4 transmitters on the receiver.
You might want to use a payload that contains a device ID so you know which packet is from which transmitter.
Thank you very much for your quick response!
So is there anything I should consider outside of id and transmission time to avoid conflict?
Thank you so much for your quick reply! So, are there any other factors besides the ID and transmission time that I should consider to avoid collisions?
All devices must be set to LoRa P2P mode, and using the same
- frequency
- Spreading Factor
- Bandwidth
- Preamble Length
- Code Rate
You can set these with an AT command AT+P2P=....
The receiver must be set to RX mode with AT+PRECV=65533
The transmitters can send with AT+PSEND=30303031
