I am not sure what happened on your modules but if it is not detected as COM port or external drive (and your hardware is ok - USB cable good, PC connection ok, no issue on power, etc.) then you might need to reupload the bootloarder using external tools like Jlink or RAKDAP1.
PS, your initial message is confusing since you are converting to RUI3 by using WisToolBox. Meshtastic RAK4631 will not work on WisToolBox. WisToolBox only work on RUI3 RAK4631-R.
Thank you for the response. let me clarify, inventory is sparse here in the states, we get our stuff from Rokland but we get the meshtastic kits from amazon.
the RAK4631 Arduio bootloader does not interface well with WiseToolBox but it offers to do an upgrade to RUI3. it fails every time. it did not used to fail.
WiseToolbox lets you manualy select the RAK4631 and then gives you a nice large “updrade to RUI3” button.
on the bricked units I was able to sucessfully flash the bootloader with a DAPLINK and pyocd. so I was able to recover the bricked units. used the most uptodate HEX file. So all is well in my world …
I am simply going to flash via the DAPLINK… in the future.
